#46
how many miles
1993
rodeo 162000 major prob well i'm not sure yet here a ticking sound need to find operating oil psi been reading other post lots of good info |
#47
Re: How many miles do you have your Isuzu?
1997
3.2 SOHC auto 94,000 New lifters, rocker shafts, timing belt, exhaust, ABS speed sensor. |
#48
Year: 1997
Engine: 3.2L Mileage: 77,000 Any major problems: No MAJOR problems. Regular maintenance Timing Belt, water pump (but couldn't get the tensioner, so i didn't change it) |
#49
1994 passport
3.2 v6 135000 -transmission @ 134999 mi -134000 mi -t-belt -t-belt tensioner -water pump -spark plugs/wires -valve cover gaskets -spark plug tube seals -2600 watts of audio installed -a/c compressor -windsheild wiper blades |
#50
1995
v6, 5spd. 235,000 i did normal/recommended maintenance No major problems...A/C compressor, alternator. (SOLD last year) |
#51
1999, 4 cyl, 2.2 with 104,000 miles
Waiting to have my fuel sending unit replaced, other that the recalls-this has been a very reliable vehicle! Would buy another if they still made. |
#52
1994
3.2 V-6 217,000 1-Timing belt, 1 clutch, 1 Alt, 3 sets plugs, break pads, tires |
#53
'96 Passport
3.2L V-6 58,000 miles Replaced alternator last year, along with rear brake rotors. Aside from that a new set of spark plugs. Otherwise no problems in 2 years. |
#54
Year: 2002
Engine: 3.2L V-6, 2wd softtop Mileage: 72,000 -Any major problems: Nope....purrs like a kittie and fun on the freeway. -Minor probs: ABS sensor replaced at 45k - Accumulator piston cover leaked...replaced. **Installed KYB shocks at 70k...MAJOR improvement!**
"Little Blue War Pony!!"-2002 Isuzu Rodeo Sport Sparkly-Blue 3.2v6 2wd softtop....0-60 8.0secs =) Last edited by Joihan777; 05-23-2005 at 10:25 PM. |
#55
1993 LS
http://www.vigils.net/users/christop...ges/cars/isuzu 174K on odometer, replaced broken which read 30K more Potentially 204,000 or more.. Peace, Christopher Vigil |
#56
1994 LS 4x4 bought new
3.2L v6 135XXXmiles Work done: O2 sensor ~110k Starter ~110k Never done brakes! New spark plug wires. The old ones would pop off. Drivers window regulator replaced Timing belt and tensioner Transmission flush with new filter-oil smelled burnt current gremlins I haven't gotten around to yet: rear window is not working from either drivers or door switch. The "Tick". Smog last time almost failed, which has never happened. I was thinking the idle air control valve. BTW. I used to go 10-15k on oil before I changed it.( why do you think I deserve the "Tick") I also just changed the fuel filter for the first time ever. Just had to cut it open and look at all the thick crud on it. 5 years ago it was repainted because a tree fell on it. Damaged the hood/grill, windshield, new roof put on and generally scratched the heck out of it. Other than the crappy ride, which I might do the Tokico springs and shocks to fix. I have enjoyed this SUV.
email"A.F."in subject line only ![]() Mt. Hamilton 9/03 Kevin Goto 2000 740 i Impala Brown Annalisa |
#57
Year: 97
Engine: 3.2L Mileage:147K Any major problems: Replaced: Water Pump, Timing Belts (twice), Radiator re-cored, Alternator, Starter, Valve Cover Gasket, Power Locks and Windows control on both driver and passenger side front doors (still don't work right) |
#58
2000 Rodeo
4 cylinder (stop laughing, I think I'm the only person who ownd a 4 cyl!) 66,400 miles Fuel sending fixed last year. Suddenly has a rough idle! Changed plugs, wires, cleaned throttle body, cleaned EGR valve, cleaned fuel injectors, replaced fuel filter, etc. Still have the problem! |
#59
1993
4WD V6 3.2L 5spd 176,000 miles Major problems: 1) Oil leak due to head gasket @ ~30,000 miles. Part of the fix was installing revised spark plug cables. Minor problems: 1) Rear power windows don't work. 2) Back window not latching properly (replaced latch spring @90k and need to again now) 3) Intermittent engine ticking when cold or after running engine for long periods at high speed (has not been a problem in a while but when it was, changing oil more frequently seemed to help). 4) Clunk when turning. 5) Gasket in exhaust pipe failed @ 170k - replaced; cheap repair. 6) Engine uses 1 qt. oil per ~1500 miles. 7) Replaced driver side power window switch assembly at ~135k. Maintenance: 1) Changed timing belt, water pump, and fuel filter every 60k so far. 2) Rear rotors and brake pads replaced at 120k. 3) Front pads (and rear ones again) replaced at 165k. 4) Changed plugs, coolant, and air filter every ~30k so far. 5) Changed PCV valve twice, although probably not needed. 6) Oil/filter changes with 10W-40 every 6-7k. 7) Changed spark plug cables at 150k. |
#60
2001
V6 53555 Just purchased - hoping for the best!!!
Helllooo! I'm just a girl!! |
