Old 02-14-2005, 07:01 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Turbo
ok ignore everything you or i have said before. even if the engien you bought is the same as a 4g63 you STILL NEED A WIRING HARNESS, ECU, AND SOME OTHER CRAP to make it work in a eclipse that came with a 1.8. the transmission is different too but that just means its weaker and has different gear ratios.
look up what you need to do to swap a 2.0 turbo motor into a 1.8 eclipse. thats basicly what you are doing only without the turbo
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-14-2005, 08:10 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Re: Turbo
im not getting a transmission.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 02-14-2005, 08:18 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Turbo
you would need the transmission too if you were getting a 1.8 because otherwise it wouldn't bolt up.
95 Talon TSI AWD
97 Eclipse GST
Old 02-15-2005, 04:16 PM
Re: Turbo
alright i said screw the 4G67.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
Old 02-15-2005, 05:16 PM
Re: Turbo
FINALLY lmfao
-1stGenRocks-
Old 02-15-2005, 09:19 PM
Re: Turbo
yeah i know lol
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
