Go Back   Automotive Forums .com Car Chat > Automotive Art > Car Modeling > WIP - Muscle Car / Hot Rod
WIP - Muscle Car / Hot Rod Post topics for any "Works In Progress" Muscle Car-Hot Rod vehicles projects in this sub-forum.
Old 04-01-2005, 08:55 PM   #46
Murco
Maximum Car Guy
Murco's Avatar
Send a message via Yahoo to Murco
Re: Re: 1/12 69 Camaro Pro Street
Originally Posted by Ralphlovs1969Cars
Im having a little trouble with the tubing for the turbos. The aluminum tubing keeps on quinking and/or braking when i bend it..
Fill them with salt and cap the ends with super glue - no more kinks!
My AF Classic Model Car Gallery
Murco is offline   Reply With Quote
Old 04-02-2005, 10:32 AM   #47
Ralphlovs1969Cars
Ralphlovs1969Cars's Avatar
Thanks for the Tip Russell im going to try it!!! Ever have luck with this method before?
Ralphlovs1969Cars is offline   Reply With Quote
Old 10-06-2005, 09:07 PM   #48
Ralphlovs1969Cars
I know it has been a while and some of you probably wondered what has happend in the last couple of months. Well i moved to a new house. Since i did not have the tubbing i needed the project sat. I decided to make a chassis from brass but i did not know how to solder. I practiced on a 1/24-1/25 scale model camaro and Impala role cage and i got good results. So off i went to start on the 1/12 Chassis. When i opened the bax the project came in the body was cracked so i had to start on a new 1. heres the progress so far but maybe the turbos wont be used until i see how i can work the turbos in with the brass chassis. Keep in mind im not going to make the hole chassis from brass. It will be a mix of plastic and brass. Take a look and leave comments, Enjoy !
Old 10-06-2005, 09:37 PM   #49
D_LaMz
D_LaMz's Avatar
Wow!
D_LaMz is offline   Reply With Quote
Old 10-06-2005, 09:46 PM   #50
mike@af
Captain Over Engineer
mike@af's Avatar
Ralph, What did you do with that cracked body? I'm looking for the 1/12 69 Camaro body for my next project.
-Mike
mike@af is offline   Reply With Quote
Old 10-06-2005, 10:23 PM   #51
Ralphlovs1969Cars
Like a Dummy i through it away. Your the second gentlemen that ask me that same thing. At the large scale forum someone wanted the body also and said it was repairable. I through it away that very same day and then i posted it on the forums a couple of days later. If i would have know i would have saved it. Do you need anything else Mike?
Old 10-06-2005, 10:37 PM   #52
Murco
Maximum Car Guy
Murco's Avatar
Wow!!
Looks trick, Ralph!!
Yes, I have used the salt-in-tubing trick and it works very well... When soldering tubing I use a small propane torch, pure silver solder, and acid flux. I first make sure the joint is making perfect contact, surround the joint to be soldered with insulating clay, flux the joint area, slice a small (very small) piece of solder off the roll and lay it on the joint, then hit it with the torch. In about 3-5 seconds it melts and instantly joins the parts with very little excess left to remove.
I learned this technique from Augie Hiscano, the metal master!!!
Old 10-06-2005, 11:42 PM   #53
Ralphlovs1969Cars
That is how i been doing it. I was using a soldering gun but that took too long and it heated up all the brass. This is quiker and it only heats up one area. When i do it i, i do it just like you said but i heat up that area first and then i add the solder.
May Augie Hiscano rest in peace.......
Nice to hear from you again! When are you going to start that project Russell?
Old 10-07-2005, 04:33 AM   #54
Murray Kish
Getting Old...
Yikes! (I'm pretty sure I couldn't do that...)
Murray
Murray Kish is offline   Reply With Quote
Old 10-07-2005, 04:49 AM   #55
primera man
"P-Man"
primera man's Avatar
Crazy looking work. Well done!!
View All My Models Here.
primera man is offline   Reply With Quote
Old 10-07-2005, 07:19 PM   #56
Murco
Maximum Car Guy
Murco's Avatar
I didn't even know he had passed! That's how out of touch I am with modelling lately. I'll never forget meeting him in 2000, how he'd let me hold some of his creations without hesitation for a closer look, and how he actually worked with me on the 2nd ZL1 Camaro in the motel meeting room when I met him at the B'ham NNL.
After I finish installing the ZZ4 and the new Baer brakes on the real Camaro I'll get back to the "Ultimate Camaro" and do some more metal detailing as a tribute to Augie!
Old 10-07-2005, 07:33 PM   #57
Dean23
Dean23's Avatar
Wow great work. Looking good so far. cnat wait to see more progress on it
Dean23 is offline   Reply With Quote
Old 10-08-2005, 08:27 PM   #58
white97ex
white97ex's Avatar
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
that frame is SWEET
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
white97ex is offline   Reply With Quote
Old 10-09-2005, 09:44 AM   #59
GvEman
GvEman's Avatar
looks good man! The turbo setup will be no problem i gues.
Best Regards
Anton
GvEman is offline   Reply With Quote
Old 10-10-2005, 05:45 PM   #60
Ralphlovs1969Cars
Actually the turbos are being a little difficult to install in this car as there is No room in the engine compartment. Im trying diffrent mock ups as we speak.Trying to route the intake tubbing and exhaust tubbing is going to be a job in itself.The problem rigth now is that the upper control arms get in the way along with the Master cylinder. I been looking for pictures with twin turbos in this same car but they all have small blocks in them and not big blocks like mines. I might just go with a blower or a tunnel ram. Im still pondering about that.....
