#46
Re: Lets play "Name that part!"
looks like a gearbox support bracket to me....
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!! 9b turbos with manual boost valve mod set @14psi turbo xs type h-rfl blow off valve blitz dome filter sachs clutch completely de-catted fuel pump voltage rewire mod ebc redstuff front brake pads greddy fully automatic turbo timer now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
#47
k3smostwanted was the closest! its a REAR crossmember, from the FWD model. [it MIGHT house the rear gearbox/differential, but i dunno since i don't have a VR4.] i should know b/c 1) i took the picture, and 2) i just finished replacing the rear crossmember and other rear suspension parts. it wasn't that tough, but i used about 1/2 a can of rust penetrant, losts of brake cleaner, an impact wrench. other than that, just a little elbow grease and it was a simple job. so if anyone needs any work done, gimme a holler!
here's another picture for your viewing fancy... have fun with this one!
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
#48
Rear camber arm, looks to be the passenger side.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions. |
#49
CORRECT! but the only way you might have known it was passenger side was the way in which it was bent, b/c the camber/control arms on the rear suspension are interchangeable for both passenger and driver sides. here's a pic for what a control arm SHOULD look like, adn what mine did look like. note to self: don't take curves at 70mph anymore, my car is not a VR4, and therefore will not handle like a VR4, and there will be resulting suspension damage.
here is some of the chaos... here's the old damaged crossmember. circled in red is where it was bent (compressed) by the force of hitting the passenger rear wheel on curb at 60mph. the other one is the new undamaged crossmember.
#50
Re: Lets play
i can vouch for that...i have 4 bent/cracked wheels from getting ran off the road by a drunk driver at about 30mph. left some nice sized chips in the curb though...
ZedEx Crew Member #4
#51
ouch, wont be hitting turns a 70 in that case.
#52
next part
#53
just a pic i had laying around. i'll try and get some more tricky pics up soon.
#54
rear sway bar....
sorry I don't have any pics at the moment... someone take my turn.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
