Old 01-05-2009, 08:11 PM
Banditxkr Banditxkr is offline
Re: Procedure to unlock the radio
Originally Posted by nineball481
If you try this, please let me know if it checks out. This could save people a lot of time and money.
Date Published: 2002-05-26
Submitter's Name: Ioannis Hadjiioannou
Email Address: [email protected]
Corvetteforum.com Member Alias: Hex29a
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can “unlock” your radio and then “re-lock” it with a new code if you wish. Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner’s manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140
08. Press 1 then # (pound). You’ll hear “Invalid Code, try again”
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code.
Note: This tip originated from LOTZAHP, Austin TX (credit must be given where credit is due). I verified it on an Y2K C5 with a locked radio - mine.
I hope this helps, I found it on a corvette forum, should work fine with your radio. Again let me know how this turns out. Please.
Jake
-nineball
I hear this worked for a lot of people, but when i enter the number in step 9 in says invalid.
Any ideas guys?
Old 01-05-2009, 08:27 PM
nevermind i got it.
Thanks for being here
Old 01-05-2009, 09:16 PM
wafrederick wafrederick is offline
Banned
You cannot use this procedure wth 2001 and up GMs.Has to be done with the Tech 2 and is faster than the old procedure
Old 02-05-2009, 05:09 PM
madyareh madyareh is offline
Is there any other way to enable the RDS radio besides taking it to a dealer? I have access to a code reader and programmer for the regular error codes. Any way thorough that method?
Old 02-09-2009, 12:20 PM
Actually, my rds radio is from a 2002 or 2003 Pontiac Sunfire and I am trying to put it in a 2000 Chevy Cavalier. Is this even doable? Can the tech 2 even mesh these dfferent systems? I don't want to pay a dealer to tell me he can't do it.
Old 03-22-2009, 12:33 AM
ValvolineManOfPa ValvolineManOfPa is offline
I'm glad I found this.....I have a 95 Lumina and I got a radio out of a 97. It was locked. Now, after looking at this thread, went thru the procedure.....it works now.
Thanks for the help!
Old 04-01-2009, 12:40 PM
rueben25 rueben25 is offline
Can someone PLEASE tell me how to unlock the radio on a 2003 chevy cavalier??? I tried the pressing the minute button and holding 2&3 thing and nothing even came up?? PLEASE HELP!!
Old 04-30-2009, 11:29 AM
Streetwise's Avatar
Streetwise Streetwise is offline
Send a message via Yahoo to Streetwise
I used the code # 106010 for my 2002 Silverado.
Old 05-27-2009, 11:30 PM
pivetti pivetti is offline
512 and 515 for a 2001 gmc jimmy. i need the code! thanks
Old 05-28-2009, 04:30 PM
zzyzzx2 zzyzzx2 is offline
Anyone worried when they might cut off this phone number? I mean, with the GM bankruptcy and all.
Old 06-22-2009, 12:08 PM
urtdog31 urtdog31 is offline
ok can someone please help me out, I have a 99 tahoe and the power was disconnect and now my radio is locked, I don't have the manual for my truck at all and I looked on here and found some instructions, everything worked so far except this part
I tried entering 8 and 9 but 3x it's says it's wrong and then hangs up... can someone please help me out so I can have music in my truck again!!!!!!
Old 07-19-2009, 11:22 PM
slyshooter slyshooter is offline
Hi,
I imported a 2006 Chevrolet Blazer from Canada to Saudi Arabia, and got a locked radio in.
the 2&3 button thing doesnt work tried it many times and tried it with ignition on , car running all sort of ways.
Is there anyother way out? Wanted to go to dealer but we have only 2 located in our city and they have one hell of a rush. Probably would waste my whole day there if i dont get a solution.
Old 07-20-2009, 09:06 AM
Post the codes from the radio and maybe someone here will call the 800 number code for you. I'm assuming you are getting the Theftlock code.
Old 07-26-2009, 09:47 AM
superromantic superromantic is offline
Hello everybody,
Thank you very much for this valuable information.
I have an inquiry please.
Kindly tell how to disable the Theft code.
6CD Bose player in my Envoy XL SLT 2003
I live in Saudi Arabia, Middle East and the car came from the United State and the Radio frequencies here in Saudi is different.
I went to dealer shop he checked and said it's locked I can't reconfigure it to Middle East (I think he doesn't know how :-( )
So I need to disable the Theft Code and go back again to him ;-)
Or I will be very greatful if you have a way to do so by myself and save my money.
Thanking your kind co-operations,
AJ
Old 09-24-2009, 12:44 PM
lkbcpa2b lkbcpa2b is offline
I am having trouble unlocking my radio on my 00 tahoe. The 1-800-537-5140 139010 does not work. Someone please help. My six digit code is 672676.
