| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs |
Show Printable Version | Email this Page |
#46 | ||
XTerra Guy
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001
#47 | |
So to clarify, you can keep your extended-length shocks with the Darlington shock mounts and SLR AAL's if you also throw on lift shackles, which raise the upper shock mount to compensate for the raising of the lower shock mount by the Darlington mounts. Correct?
And again, I have OE length shocks, which will be fine when coupled with SLR AAL's and the Darlington mounts but without shackles. Brent |
#48 | |
From what I was hearing from Kennedy. He said that that if you have the longer Bilsteins you can use the Leave spring skids, They will mount the lower shock bolt lower on the skid to compensate for the long shock.
If you are running stock Length shocks, then they will give you the skids with the higher bolt location, again to compensate for the length. They vary the bolt location based on your setup. From what he was telling me, they can accomodate pretty much ANY configuration, stock shock/ AALs, Extended shock, Spring pack.. Just drop them an email and they can pick out which setup is right for your rig.. I'll be getting a set of those soon. My lower shock bolts arent coming off without the aid of a sawzall. I hope this helped. I think he stated this earlier in this thread. L8r
'01 Salsa X XE Bone Stock, No really. ;-) |
#49 | ||
We don't give a damn how loud your stereo is! Did you read your owners manual yet? V.P. of PNWX |
#50 | ||
If you are putting in AAL's and shackles you'll want to extend the bumpstops anyway to avoid having your tires destroy the inside of your fenders when stuffed (more droop on one side means more stuff and increased tire angle on the other side). Does that make sense?
ChuckH |
