Old 06-21-2006, 02:27 PM
05chevyguy's Avatar
05chevyguy 05chevyguy is offline
Send a message via AIM to 05chevyguy
Lightbulb Re: How To:Door Molding/Badging Removal
hey,
i have a 05' silverado and i have the big chevrolet letters across the tailgate. i was wondering if there is any way to get those off?
thanks.
preston
Preston---
05' Chevy Silverado, 4.3L v-6, short bed, regular cab. sung top tonneau cover.
Old 06-21-2006, 11:12 PM
01silverado03z400's Avatar
01silverado03z400 01silverado03z400 is offline
Send a message via MSN to 01silverado03z400
Originally Posted by 05chevyguy
hey,
thanks.
preston
grab a blow dryer or a heat gun to heat the letters up and then peel them off.
NEW - 2004 Chevrolet Silverado 5.3L RCSB Z71 Hooker AeroChamber - Black Bear Tune - Welds - 33" Mickey Thompsons
01 Silverado 4.8L ECSB 4x4 True Flow - Magnaflow - Black Bear Tune - 35" BFG A/T - 4.56 Auburn SOLD
83 Sierra RCSB 2wd 350 Under construction
Old 06-21-2006, 11:36 PM
05chevyguy's Avatar
thanks for the suggestion.
x
Preston---
Old 07-10-2006, 06:30 PM
GARY"REDBONE" GARY"REDBONE" is offline
Try Avon's Skin So Soft Bath Oil. It will not hurt the finish & it's also great to remove tar, oil, and chewing gum. Also takes scuff marks and crayon off floors & other hard surfaces. Just another 2 cents worth.
Old 08-08-2006, 01:21 PM
thormx219's Avatar
thormx219 thormx219 is offline
Send a message via Yahoo to thormx219
I just bought an '06 1500 ccsb and I'm Thinking about removing the door molding, but I would like to see what it looks like, before I do it.
Does anyone have an after pic ??
P.S. 1st post.
Love the site, plan on spending alot of time in here while I'm supposed to be **cough, Hack**at work **cough**
Old 08-19-2006, 05:55 PM
cdemato cdemato is offline
Send a message via AIM to cdemato Send a message via MSN to cdemato
P.S. 1st post.
Heres a pic of my '05, that molding looks like crap after about a year of sunshine. I opted to remove and insert graphic. My truck is dark, but you get the idea.
Old 01-23-2007, 11:38 PM
mrrose mrrose is offline
You guys are making it way to tough on yourself. I can remove a moulding in about 2 minutes or less. Go to your local automotive jobber, get a flat blade moulding tool, use it by hand or put it on your air hammer, Then buy an eraser wheel, it goes on the end of your die grinder or cut off wheel. buzz the tape off in 1 minute, if you must roll off by hand, use a little heat, a blow dryer is fine. keep it dry, unless the tape is old a brittle, then use adhesive remover by 3m. it is cheap, and removes all sticky crap,
Old 11-15-2007, 12:58 PM
Bigg G Bigg G is offline
I peeled my door trim, badges and tailgate panel trim off my truck first and then used 2 $9.00 eraser wheels to remove the left over glue on my 95 Silvy. All you need is a drill and eye protection and it's done in less than hour.
I'm a BOWTIE nut !!!
Old 04-28-2008, 02:11 PM
jrobin3671 jrobin3671 is offline
Neat trick for getting the glue off. Quite often works well without damaging paint/clearcoat.
Take a can of compressed air that you can purchase at Radio Shack or the computer accessory section at wal-mart. Normally, the can is held upright, and while spraying a keyboard the can becomes quite cold. If you invert the can (hold it upside down) and spray a small area of the glue (3-4 sq. in.) the glue will freeze. You will see the frost. Allow to sit for a bit, depends on how hot it is it your area. When you see the frost beginning to dissappear around the edges of the area you sprayed, wipe the glue off.
If you have a small dent that has NOT creased the metal, heat the area with a blow dryer for about 1 min. Quickly spray the area in the same manner and give it a good freeze. Simply let it thaw out. The change in temp makes the metal expand, then contract and when it expands back to normal temp, it resumes the same it was originally made into, provide no crease or other factor prohibits it.
Old 11-15-2008, 11:04 AM
T Wrecks T Wrecks is offline
You can try using an AP or 3M eraser wheel. You can chuck it in a drill and go to town. I use it on everything from pinstripe to molding adhesives.
