Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
View Poll Results: Altima SE V-6 or Impreza WRX?
Nissan Altima SE V-6 23 31.94%
Subaru Impreza WRX 49 68.06%
Voters: 72. You may not vote on this poll
Old 01-19-2002, 10:57 AM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
10hp exh on altima? hmm...
the subaru intake is worth 10hp... its a turbo motor getting more air... it will naturally make more hp than a regular intake on a n/a car.
double clutching 3rd to 1st while moving sounds like a recipe for a bomb in any car... im sure i would blow my diff if i did that while i was moving...
Old 01-19-2002, 03:36 PM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
He was only going about 15 or 20 mph. He wasn't mashing on it, he was just eating a burger and hadn't downshifted and he needed to be in first.
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 01-19-2002, 03:48 PM
that is really fast for a downshift to 1st from 3rd... even from 2nd to 1st... for me that is tough to do even at like 10mph from 2nd... i cant imagine that being a nice thing to do to a trans, let alone your diff...
Old 01-19-2002, 03:55 PM
Gonthrax's Avatar
Skyline Guy
Yea but thats what the double clutching is for, you match the RPMs so your syncros don't have to do all the work. that way it just slides into gear with no trouble.
Neishlin Motors
Old 01-19-2002, 09:32 PM
Morpheus XIII Morpheus XIII is offline
Originally posted by Gonthrax
Whats the Altima's engine code? QR35DE?
*Edit*
No those are in Sentra's right? KA35DE?
The Altima 2.5 engine is a QR25DE inline-4. The Altima 3.5 engine is a VQ35DE V-6. The older Altimas used the KA24DE, the same engine in the 240SX.
Old 01-19-2002, 09:44 PM
About taking modifications:
The WRX already being turbocharged can easily and cheaply add-on more horsepower with items such as intercoolers, boost controllers. You can find a good 50-100 hp from aftermarket turbo items for no more than $2000.
The Altima 3.5 on the other hand will cost a LOT to turbocharge, but in the long run, can be made to produce as much as 600-1000 hp, much like the other modified 6-cylinder turbocharged Japanese motors. The WRX being a 4-cylinder will have its limitations in how much boost it can take (probably around 500 hp max) even with all the block reinforcements. Of course, this route for the Altima will cost enormously, probably anywhere from $7000-$???, and then the sky's the limit.
As for intake and exhaust, turbocharged cars generally take the reduced backpressure better, while naturally aspirated cars prefer the freed-up breathing.
Old 01-20-2002, 12:39 AM
F20C's Avatar
F20C F20C is offline
20 mph is a bit too much to go down to one. No reasons why he needs to do that. 2nd gear is more than adequate to do the job at that speed. There is better reason for downshifting to 1st gear however eating burger and needing to downshift doesn't cut it. I would say that's more human calculating error than mechanical failure.
Old 01-20-2002, 12:43 AM
F20C's Avatar
I heard stock internals are probaly good for 400 ps.
Old 01-20-2002, 02:07 AM
Likely. If the next GT-R uses a turbo VQ35, it is supposed to pump around 450hp. Not too shabby at all. If this happens, then the engine should be able to get into the quad digit horsepower level with block strengthenings and higher boost, as I mentioned earlier.
Old 01-20-2002, 02:09 AM
Gonthrax's Avatar
Skyline Guy
Your probly right, I donno what RPM you would be at in first doin 15 or so in a rexy.
Neishlin Motors
Old 01-20-2002, 03:12 AM
F20C's Avatar
For my car I wouldn't go back down to 1st gear if I am past 3000 rpm in the 2nd gear. There is only very few case where I needed to shift down to first at higher speeds. It has something to do with traction when you fish tail.
Old 01-20-2002, 05:13 PM
Gonthrax's Avatar
Skyline Guy
Ic ic.
By the way, how do you like your S4? I have been wanting to drive one for a while now.
Neishlin Motors
Old 01-20-2002, 10:15 PM
F20C's Avatar
A4's getting dated fast. Need to start looking for replacement soon.
Old 01-20-2002, 10:29 PM
Gonthrax's Avatar
Skyline Guy
really? What are you considering?
Neishlin Motors
Old 01-21-2002, 10:33 AM
F20C's Avatar
The time is not right since most of the import models are just starting to arrive. Probaly wait another year to change the car. Cars on mind right now are RX-8, Lancer Evolution, WRX STi and next generation S4.
The New Subaru Canada WRX STI Spot subarucanada General Discussion 1 07-13-2012 01:44 AM
Top Gear Australia featuring Nissan GTR and Subaru WRX trev0006 Car Videos 0 11-13-2008 11:11 PM
Tuned Subaru WRX STI vs Procharged Nissan 350z trev0006 Car Videos 0 10-29-2007 06:09 PM
Nissan Skyline GTR vs Mitsubishi Evo vs Subaru WRX on snow trev0006 Car Videos 0 11-16-2006 09:32 PM
Acura 3.2 CL Type-S Vs Nissan Altima SE V-6 GOD Car Comparisons 32 11-29-2001 01:17 PM
