Old 06-11-2016, 11:34 AM
20GMC00 20GMC00 is offline
Re: 2000 C2500 stuck in closed loop.
Went to drive it today and it won't start unless I put the pedal to the floor. Then when it starts it barely has enough power to move. I plugged in the scanner to see what codes there were and it's not even powering the scanner on.
Old 06-11-2016, 11:44 AM
rhandwor rhandwor is offline
Auto Zone or Advanced Auto has loaner tools. Get a fuel pressure tester and check the fuel pressure. Post the results.
Old 06-11-2016, 12:37 PM
j cAT j cAT is offline
scanner tool gets power from cigar fuses. see if the power sockets have power check fuses.
Old 06-11-2016, 03:44 PM
Fuel pressure is at 62 psi when the engine is running. Changed the fuse and still only getting P0174. Pickup has no power to move itself and shakes very bad.
Old 06-12-2016, 10:11 PM
I got it home going about 5mph. Couldn't go any faster. Luckily I was only a mile from home.
Old 06-13-2016, 07:24 AM
Blue Bowtie's Avatar
Registered Offender
This now sounds like flooding. Perhaps a leaking injector, regulator, or fuel line in the plenum. Does the fuel pressure drop off quickly once the pump is shut off?
Old 06-13-2016, 09:25 AM
I will check that tonight. I thought it sounded like the timing was off. The hold down on the distributor was tight but the paint mark was way off. Not sure what happened there.
Old 06-15-2016, 07:24 AM
I also took the cap & rotor off and they are toast. They are probably 5 years old. Isn't that a little soon to be shot?
Old 06-15-2016, 08:17 PM
Turning the key on is 65 psi. Turn the key off and the fuel pressure drops to 0 psi in 5 seconds.
Old 06-15-2016, 10:02 PM
Registered Offender
That could be a regulator, fuel line, or the pump leaking back. Based upon the reported symptoms it sounds like the pump may not be the prime culprit.
Old 06-16-2016, 08:15 AM
No fuel lines are leaking. The spider assembly and fuel pump are new. What's the best way to find out what's leaking?
Old 06-16-2016, 05:31 PM
With the return line pinched off the pressure still drops right to zero. Would that mean the check valve in the pimp is bad? Thanks.
Old 06-17-2016, 10:15 AM
It was spraying out of the regulator.
