| Latest | 0 Rplys |
#481 | |
Re: Passlock System
Does any one have a link for by passing pass lock on 20004 impala?
#482 | |
Re: Passlock System
bump
#483 | |
Re: Passlock System
first. not to be lame, but... P.A.T.S., V.A.T.S., passlock, passkey, ect. are basicaly not much different. If you don't know what to call it because you don't know much about cars or trucks, ... thats ok, everybody, including me was there once... It is called a .."TRANSPONDER BASED SYSTEM"... I didn't need to go through auto. school and years of expirience to tell you that, even though I did, mabey,,,just to tell you that. Now I'm NOT trying to be a jerk or p@@@ anyboy off but this is my first day on this and I don't get on comp's. very much but I do know something about automotive technology.
#484 | ||
Re: Passlock System
The best and cheapest way to completely fix this is to do the following..... Tools: Ohm meter, wire strippers, wire crimpers, needed resistance value in resistors. Get behind the ignition switch. See large harness going to ignition switch. Open up that harness and you should see a bunch of large gauge wires. Look closely and you should see 3 tiny ones (yellow, black, and white). Grab the black and yellow wires. Start the car (hopefully security goes off). Cut yellow wire and meter the cut end that's toward the ignition switch and the black wire. Then meter that cut yellow wire again but next put the other lead of the meter to chassis ground. Which ever value is higher get a resistor(s) that closely match that number you got when you metered those wires. Take the OTHER end of the cut yellow wire and install the resistor to it and then to the black wire or chassis ground. Shut car off and start it. Light should go out. If the car starts then stalls, you may need to adjust the resistance value. If security light is on, verify that you have the correct end of the yellow wire attached to the resistor. If so, it should go out on its own after a while. If your light was on steady before doing this repair and is still on, you may need to do the relearn sequence. This is the ONLY way to disable this system and not have to worry if your car's battery goes dead.
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
#485 | ||
Re: Passlock System
#486 | |
Re: Passlock System
You don't. You go to Radio Shack, buy something like a 1500 ohm resistor, install it by the method I stated, crank over the car, let it sit WITH IGNITION ON for 10 minutes, try to start it again (may have to do the 10 minute interval more than once). Then you are done. It should eventually take the new code unless your BCM is toast. Oh, if your car's battery is weak, make sure to have a charger on it while you do this repair.
#487 | |
Re: Passlock System
Let me first say thank you to Ray and Poncho, you guys have provided a tremendous help to those of us with this passlock problem. And those pictures you linked to Ray are awesome.
I have a 2003 Old Alero. Let me see if I have this right. It is a Passlock 2 system. There is no transponder in the key itself, and any key copy should work as good as the next. I need to either put a switch in or a resisitor. I can try the resistor trick first and if it doesn't work I will put a switch in. Am I on the right track. |
#488 | |
Just wanted to say thanks to everyone for posting information on this problem.
I have a 2000 Pontiac Grand Am SE and all the associated problems (squeaking interior, brake problems, infamous leaking coolant gasket, and blinking security light). I do have a quick question regarding remote starters. Reading some previous posts, a remote starter shouldn't experience the passlock issue. However, I have had 2 different remote starters on this car and both have occasionally received the blinking security light when using the remote starter. After 10 minutes, I can start the car fine. Do you think the resistor fix will still work for me? Could it be something else causing this problem? I was going to end this post with a "Member of the Anti-Passlock Club" but I think I'll go with "Member of the Anti-Pontiac Club". Scratch that, "Member of the Death to GM and their shitty cars with shitty service Club" |
#489 | |
Re: Passlock System
I have a 2001 chev malibu with this same pass lock issue and found this thread very helpful thanks to all. Now my question is, after fixing the yellow wire i now have no cranking at the key if i jump the starter it starts is this related to the ingnition switch or a different problem? any help would be appreaciated. thanks
#490 | ||
Re: Passlock System
Last edited by MontanaDude; 10-05-2009 at 08:13 AM. Reason: Actually 4.7K and 2.2K in parallel are about 1500ohms. Sorry for the confusion. |
#491 | |
Re: Passlock System
Just a follow up. This worked like a charm, and now the security light is OFF all the time. Thanks a ton you guys, this place is awesome
#492 | |
Re: Passlock System
no problem just glad you finally got it.
#493 | ||
![]() Join Date: Nov 2008
Re: Passlock System
I should have said "CAN play havoc with the factory system." I have seen it dozens of times.
* GM Technician JK * |
#494 | |
![]() Join Date: Nov 2009
Re: Passlock System
Hi guys,
Newb here trying to figure out my friends grandpa's ( WW2 vet ) 97 malibu with 3.1L Auto, 133K miles. Car is driving down the road and all of a sudden cuts out. Won't start for about 20 mins. Then starts fine. Im thinking the ignition switch is bad. I did tell him to just use the key itself with no heavy rings on it. This maybe isnt related to Passlock but it could be so I thought id get some advice here. I have yet to test the alternator, battery cables and clean out the ignition cylinder. If it is a bad key cylinder anyone have any instructions on how to replace the whole thing? |
#495 | |
Re: Passlock System
