Old 09-09-2015, 06:17 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
Re: SERIOUSLY OT: Calling all chicks! IT'S PART 6!!
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 09-09-2015, 10:04 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Originally Posted by BLU CIVIC View Post
That makes my eyes itch....
Old 09-09-2015, 10:15 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Honda Enthusiast
The Following User Says Thank You to Killa_CRX For This Useful Post:
TheSilentChamber (09-10-2015)
  #4879
Old 09-10-2015, 05:14 AM
Forunn Daberator
Well my mother bought a new Sonata. I popped the trunk to discover that there is no spare tire. What kind of non sense is this non sense? "No tire for youuuu... heres can of Korean Fix-A-Flat..."
Old 09-13-2015, 05:26 AM
Forunn Daberator
So... went to install the new radiator on the Grand Cherokee... Most overly complex thing in history. Everything that could possibly be bolted to or around the radiator is. Top, bottom, front, and back... all packed with crap bolted to it. I'm pretty sure step 1 in the Jeep factory is to install the radiator to the chassis... then bolt everything to it. At least I remembered not to lay under the front skid plate when I unbolted it this time... made that mistake when I changed the steering gear. Tomorrow I get to put it all back together... assuming the parts stores have the stuff I need to hook my trans cooler back up because the replacement radiator has different fittings. Also learned my fan clutch is probably bad... could explain why it sounds like a prop plane when I first start it up.
Old 10-02-2015, 08:53 AM
BLU CIVIC's Avatar
調整器
Changing the radiator was simple with the Land Cruiser. Regarding the fan clutch, I thought mine was going bad as well. I did some research on LC forums and replaced the fluid in my fan clutch. Was pretty simple and cheap. Didn't have any problems after that.
The name's Adrian
2011 CR-Z - Stock
Old 10-04-2015, 11:51 PM
Forunn Daberator
Nice. My fan clutch wasnt serviceable- the silicone goo is permanently sealed in it. But its the same fan clutch that most all american cars had for like the better part of the 20th century, so a new one was only like $50. Replaced the thermostat, water pump, fan clutch, and radiator and operating temp dropped 20 degrees. Used to run at 210, now runs at 190. Can't complain. Logged over 2000 miles already since I changed them- trekked out to Tennessee then down to Austin. Hit 196,000 miles so next up is plugs/wire/cap/rotor. I hear you can swap the old injectors for 4 port injectors and gain a little mileage, which would be nice since I'm getting 15.2 highway (single digits in town ). Living the old vehicle life...
Old 10-11-2015, 01:49 PM
Forunn Daberator
So.... would you guys hate me if I purchased a 5th gen Prelude? My jeep needs a companion.... something a lil' mo' secksi....
Old 10-14-2015, 11:34 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
soooo, I'm bringing my civic site back. Going to link af like it was on the old site. This should be interesting......
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 10-15-2015, 02:38 AM
Beagronomis Beagronomis is offline
Just thought I would stop by!
Old 10-15-2015, 10:17 AM
amy@af's Avatar
Hi long time no see!
I discovered yesterday if you are in IE, chatroom here doesn't open but it does on chrome, Firefox, and I haven't tried safari yet. I know you guys are dying without it
Old 10-20-2015, 12:03 AM
Forunn Daberator
Theres a chatroom? Oh right, that annoying pop up shit at the bottom.
Old 10-20-2015, 12:16 AM
amy@af's Avatar
Yes that thing...
Old 10-21-2015, 03:00 AM
Forunn Daberator
Yes that thing...
Hey Amyyyyyyyyy! I'm going to be in Denver in two weeks.... you going to be around?
Old 10-21-2015, 08:51 PM
Killa_CRX's Avatar
When Civics Attack!
Chatroom? bah! I haven't chatted since like 2004.
New developments... Buddy Club is garbage.... 8 months and 9k miles, and my upper control arm bushings are totally ripped/torn.
Not to mention the upper ball joint dust boots look older than the boots on my 17 year old tie rod ends...
I contacted them about getting them warrantied, but I'm not going to put them back on if they replace them... going back with Skunk2... never had an issue with them on my old hatch.... will probably put the Buddy Clubs on craigslist.
Honda Enthusiast
TheSilentChamber (10-21-2015)
