Go Back   Automotive Forums .com Car Chat > Chevrolet > General Discussion
Old 04-16-2007, 07:54 AM   #466
Onblsht
Authorized Vendor
Onblsht's Avatar
Re: Keyless Entry Info...Search here first before posting about keyless entry problems.
JSCIARRI84, if your remote is the factory GM type and not aftermarket, these instructions will program your remote:
Leave key off
Jumper pin A to pin G with a fused jumper (3A)
Doors will lock and unlock
Pres the UNLOCK button on the remote
Doors should lock and unlock again
if you have more remotes press their unlock button (up to 4)
remove jumper wire
________|________
[F] [E] [D] [C] [b] [A]
[G] [H] [J] [K] [L] [M]
_________________
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Onblsht is offline   Reply With Quote
Old 04-17-2007, 05:59 PM   #467
thehotrod11
Originally Posted by thehotrod11
Hello, I have a 2000 Pontiac Monatana and the horn and light lock confirmation has been disabled. So that when I press the lock button on my receiver twice the lights don't flash and horn doesn't honk.
I followed the procedure in my manual but apparently the confirmation feature is not programable on my version of Monatana.
I'm assuming the previous owner had it disabled by means of removing some wire or following some procedure listed here. Can somebody help me re-enable my horn/light lock confirmation?
Thanks for your support.
Bump....Any help, please?
thehotrod11 is offline   Reply With Quote
Old 05-18-2007, 05:56 PM   #468
ARTEMKA
Hey, any one know how to program a keyless entery remote for a 2002 saturn sc2, any help will be appreciated,
Thanks.
ARTEMKA is offline   Reply With Quote
Old 05-19-2007, 03:29 PM   #469
Onblsht
Authorized Vendor
Onblsht's Avatar
The 2002 Saturn SC remotes require a scantool for programming (same as the Cavalier)
Old 05-24-2007, 10:35 PM   #470
wolfer14
Hi all
I'm trying to find how to program a keyless entry for a 1994 Pontiac Grand AM SE
Any help would be greatly appreciated.
wolfer14 is offline   Reply With Quote
Old 05-28-2007, 10:10 AM   #471
woody1980
I have a 91 buicl road master wagon, do you know ware the progam wire is for wagon
woody1980 is offline   Reply With Quote
Old 06-16-2007, 03:04 PM   #472
burchboy19
anyone got the program for a 95 grand am se? thanks
burchboy19 is offline   Reply With Quote
Old 06-18-2007, 04:11 PM   #473
grandamdriver52
grandamdriver52's Avatar
Send a message via AIM to grandamdriver52 Send a message via MSN to grandamdriver52
How do you program a key for a 1995 buick regal?
1995 WaveRaider 1100 - Primer kit, Ocean Pro Vortex flame arrestors, R&D 155 PSI Race Head, Jettrim seat, 5 degree nozzle, Cut stock water intake grate, Solas 13/19 Impeller, hydro-turf, pro-tec ride plate, Riva Racing handlebars, billit throttle, rebuilt mukuni SBN 38's.
Riding a WaveRaider is like riding a p***ed-off paper plate
grandamdriver52 is offline   Reply With Quote
Old 06-18-2007, 04:18 PM   #474
Onblsht
Authorized Vendor
Onblsht's Avatar
95 Regal:
In the passenger side of the trunk, there is a wire, near the antenna.
Ground this wire, wait for the locks to cycle, then push any button on the remote and hold until the locks cycle again, and you should be in business.
You may have to reprogram your existing remote as well, as some cars erase all old codes when adding a remote.
You can do all at the same time, when done, unhook your ground wire and your finished.
Old 07-17-2007, 02:15 PM   #475
elizabeth62707
does anyone know how to program a keyless remote for a 2004 chevy silverado??
elizabeth62707 is offline   Reply With Quote
Old 07-23-2007, 11:49 AM   #476
vernusp
Unhappy Re: Keyless Entry Info...Search here first before posting about keyless entry problems.
tireburner...i just bought my son a 99 olds alero....i purchased a used remote with the same #s on e-bay....could you please instruct me on programming procedures....i hope that this message works....1st time here....thanx in advanced for any comments/help
vernusp is offline   Reply With Quote
Old 07-23-2007, 01:47 PM   #477
stageact
Can anyone provide the programing instructions for the remote to a 2002 Blazer's GM Aftermarket remote. GM P/N 12490830 MODEL/FCC ID: EZSOEMTX
THANKS!
stageact is offline   Reply With Quote
Old 08-18-2007, 08:30 PM   #478
nedudgi
Just bought a 97 Burb LT (to replace my old 97 Police Special :-) the wireless remote, both front door push buttons, and the rear side button open and close the drivers door only, the 3 passenger doors would not power open or close, not even click, but they can be opened and locked manually. Rear hatch/latch (glass flip up liftgate hatch) opens with push button on dash but not on the remote (remote is aftermarket Audiovox Premier alarm with single button to open and lock and second button to release "trunk" When I push any of the activators to close, I hear 2 consecutive relay clicks, but the doors, with the exception of the drivers doo will not open, or lock when I push lock.
Any help would be appreciated.
nedudgi is offline   Reply With Quote
Old 10-18-2007, 10:21 AM   #479
starman26
Can someone please tell me how to program a remote for a Chevy 2002 Trailblazer.
I tried the procedure that has you turn the key on-off-on-off while holding down the door unlock button on the door panel. Then holding down the lock and unlock buttons on the remote for 15 seconds.
It did not work. However the door locks did loc and unlock after doing the on-off-on-off procedures. The remotes did not cause the door locks to respond.
I suspect that there is more to the procedure for a 2002 Chevy Trailblazer. thanks in advance.
starman26 is offline   Reply With Quote
Old 10-23-2007, 01:11 AM   #480
spinn360
I am trying to figure out how to program a 92 Olds Bravada's Keyless remote I tried to do it the 96 Blazer way but it doesnt work that way so if you could help that would be great thanks. The remote used to work I was told when I got it and now it doesnt.
spinn360 is offline   Reply With Quote
