View Poll Results: Did you like this tutorial?
Yes 38 92.68%
No 3 7.32%
Voters: 41. You may not vote on this poll
Old 08-18-2003, 02:35 PM
Ran's Avatar
Ran Ran is offline
not bad.. it would be a big help if u would of allso posted the original so that we wont have to
Ran
Please read the AF guidelines
if you haven't read them before.
Old 08-18-2003, 05:38 PM
CivicLeader's Avatar
CivicLeader CivicLeader is offline
Send a message via AIM to CivicLeader Send a message via Yahoo to CivicLeader
Re: Masking Tool Tutorial
LOL...sorry bro...my bad....won't happen again...
Here is the original 350Z & CL Type-S....
p.s.
Is it the lasso tool that you use to say...lower the body of a car? I used it the other night and it worked great...only problem was that I couldn't let up on the left mouse click and that after I moved the body of the car down...there was areas where the original body was that was just black...any suggestions?
CL
Old 08-23-2003, 12:30 AM
boingo82's Avatar
boingo82 boingo82 is offline
Can't polish a turd.
Exclamation Realistic Color Change Tutorial (learn Adjustment Layers)
I have seen a lot of ill-executed color changes in my day, so I thought I'd share my method for color changing cars. The benefit: You don't lose any data, so you can change your mind later on!! (Disclaimer, start with a silver car your first time, it's easier!!)
We are going to turn this car:
into this car:
For starters, we are going to use a variation of Beefcake's Masking tool tutorial. If you haven't already read it, you should. It's stickied at the top of this forum.
First, I traced around the car using the Magnetic Lasso. It's this one, sometimes hiding under the other Lasso tools.
It works by looking for "edges" in an image and snapping to them. It's the best selection method when you're dealing with high contrast, but it doesn't work so well in my example photo. Here's what I have so far:
You can see that selection's a little rough, especially around the trunk and roof area.
Now, holding down the ALT (option on Mac) key while using my Magnetic Lasso, I subtract the windows and sunroof and headlights and door handles and anything else that's not part of my paint. (You can also hold down SHIFT to add to the selection.) ALT and SHIFT work this same way with ALL of Photoshop's selection tools.
Here's my new result:
It's still a little rusty, but that's OK. I will fix it up.
Click on your Quick Mask Mode button.
In Quick Mask mode, your selection is displayed as an image, and you can "paint" it on and off. Double-click on your Quick Mask button and set the mask color to White and the percent to 80%. Then, using your paintbrush tool, paint around the edges of your car to fine-tune your selection. I started with this:
and fine-tuned it to this:
Click back to regular mode (the icon to the left of the Quick Mask button). Now, the fun part. I think you need PS7 for this, if you don't have it, PM me and I'll explain how to do without.
We're going to make an adjustment layer, using our selection. Click the Adjustment Layer button in the Layer palette, and select "Curves".
You will see the "Curves" dialog, it looks like this:
First, since the car we're working with is a light color, to do any realistic-looking change we're going to have to darken the paint a lot.
I did this to the RGB curves, added a little blue, changed the layer mode to "Luminosity",
and got this:
Here are the curves I did for RED: (green channel left alone)
and the resulting car:
By double-clicking your adjustment layer, you can change the curves again and again, or you can throw away the adjustment layer and start all over with your original, untouched image. If you see jaggies or spots you don't want colored that ARE getting colored, simply click on the mask icon on your adjustment layer, and "paint on" or "paint off" as you would in Quick Mask mode.
I find this the way to get the most realistic color changes.
BTW, if you're starting with a car that's NOT silver, when you get to the curves part, click the Gray eyedropper and click on your car somewhere. Click around until the car color is "neutralized", then adjust from there.
Questions, comments, think I suck, etc., PM me.
Just because offense is offered, does not mean you have to take it.
Old 08-23-2003, 01:25 AM
Ran's Avatar
Ran Ran is offline
that tutorial is very nice, good work!
now ill go ahead and try it.
Ran
Old 08-23-2003, 01:35 PM
Re: Realistic Color Change Tutorial (learn Adjustment Layers)
...that was very nice and detailed...I'm going to print it out and try it when I get home....
Thanks much...
CL
Old 08-23-2003, 02:00 PM
Ran's Avatar
Ran Ran is offline
ahhh man, this doesnt work.. i tryed everything.. and just wont work
Ran
Old 08-25-2003, 12:26 PM
spididdy's Avatar
spididdy spididdy is offline
Send a message via AIM to spididdy
hmmm looks nice but ran said it dont work so i guess i have to try it
<-- yellow is rap...
^Green is Techno
Old 08-25-2003, 02:13 PM
Ran's Avatar
Ran Ran is offline
yea, it dont work when u select the car with the displasment thing.
but now that i selected it with the lasso, it works pretty well.
Ran
Old 08-26-2003, 09:58 PM
boingo82's Avatar
yea, it dont work when u select the car with the displasment thing...
I don't understand what you mean, there is no "displasment thing". Could you please tell me what problem you had so I can fix the tut or put more details in.
Old 08-27-2003, 10:42 AM
Ran's Avatar
Ran Ran is offline
oh sorry, i meant the quick mask, i used it the first time i tryed the tutorial, and it didnt color the car when i went to curves and did what u told to.
but at least now it works for me when using the lasso tool.
Ran
Old 08-27-2003, 03:00 PM
boingo82's Avatar
It might be because I have my Quick Mask settings set to "Color indicates Masked areas" instead of the default, which is selected areas. So maybe if you change that it will work better.
Old 08-28-2003, 11:02 AM
Ran's Avatar
Ran Ran is offline
o, ok, ill try it in my next chop.
Ran
Old 09-02-2003, 02:47 PM
ZVT's Avatar
ZVT ZVT is offline
Send a message via MSN to ZVT Send a message via Yahoo to ZVT
I use curves for all my chops when I change coloir it works great.
PS GALLERY!!!
Old 09-06-2003, 06:09 AM
groomi groomi is offline
how do i do it in 6???
Old 09-13-2003, 11:42 AM
numbware's Avatar
numbware numbware is offline
Send a message via AIM to numbware Send a message via MSN to numbware
another good way to do that is to go to; Image > Adjustments > Desaturate
Name's Justin and I'm 15 years old.
Numbware (My site)
