Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 03-16-2010, 10:41 AM
Gatorac's Avatar
Gatorac Gatorac is offline
Re: Motor Build
WOW. Lucky that didn't come all the way apart and try to escape through the block.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 03-16-2010, 11:00 AM
jencruz8787's Avatar
jencruz8787 jencruz8787 is offline
Re: Motor Build
Hello guys,
I am from the Philippines. I have problem with my car, It seems that sometimes It automatically turns off. My car is kinda Old, a toyota Coralla. This was my fathers car bought on 1999. Now the car belongs to me.
What seems to be the problem when a cars engine automatically turns off? do I have to modify any of the parts? I'm not really good with cars.
jencruz8787
Old 03-16-2010, 02:25 PM
NZGTRA17 NZGTRA17 is offline
Re: Motor Build
Originally Posted by jencruz8787 View Post
Hello guys,
It would be better to ask this question in the Toyota / Corolla section of Automotive Forums where other owners of this type of car may be able to help you.
Kel M
Panoz GTRA #17
New Zealand
Old 03-16-2010, 03:50 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Motor Build
Really sucks when you pay good money for good parts etc. and have crap like this happen.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 03-16-2010, 04:13 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Re: Motor Build
Hello guys,
you might want to post in the 'Yota section.
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 03-16-2010, 04:58 PM
Re: Motor Build
Originally Posted by Cobrafang View Post
Yes those are the pictures of the same crank. The shop did do some polishing/prep work. The crank came internally balanced so they did some minor work I certainly would not call it "serious".
I will try to get some better pictures with my REAL camera sometime this week.
I have not heard back yet from Keith Craft yet. I expect I will today.
Thanks for all the dialogue.
Tom, the additional pictures explain a lot more. The no. 1 throw rework is not of an acceptable standard.
This was a fatigue failure waiting to happen for a number of reasons - reduced cross sectional area to take power/rotating loads, poor surface finish (on edges as well as flat areas) providing a haven of crack initiation sites, hard nitrided outer shell has been ground off the crank reducing strength etc etc.
I have seen pictures of other very very similar failures to this on the web in 5.0 based Ford strokers. As far as I can recall these have all been engines where the crank has been zero balanced. They have had identical rework in the area that your crank has (some looked like they had been done with a disc grinder) on the no 1 throw. End result has been the same - cracked through the throw.
I know you probably dont want to hear this but the block should now also be checked. The front main will have taken a beating holding this together so should now be checked for alignment and concentricity at the very least. If it is not checked and another crank is thrown in you may have bearing issues with this main.
Kel M
Panoz GTRA #17
New Zealand
Old 03-16-2010, 05:48 PM
Cobrafang Cobrafang is offline
Re: Motor Build
Thanks Kel, I am on it.
Tom
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 03-21-2010, 01:39 PM
Re: Motor Build
Tom
Tom, any progress with determing cause of failure and resolving?
Kel M
Panoz GTRA #17
New Zealand
Old 05-03-2010, 02:32 PM
Re: Motor Build
Tom
Tom, whats the progress? Has this been resolved with the builder? What are you piecing together to replace the shortblock?
Kel M
Panoz GTRA #17
New Zealand
Old 05-03-2010, 09:30 PM
PanozDuke PanozDuke is offline
Re: Motor Build
Kel,
Talked to Tom today. Eagle replaced the crank and has the old one. They did not tell him what the issue was. The only damage to the motor was the crank and front seal and bearing. The builder is doing a complete tear down, line hone and reassembly. Tom is planning on a visit tomorrow to check progress. I think the plan is to run it in on an engine dyno and give it a good tune. The 8 into 1 Kelasaurus headers and exhaust system has been in the works for several weeks and should be nearing completion. The dyno is tied to being able to tune with the headers. He should get some word on the progress on those as well.
Mike
Old 05-04-2010, 02:32 AM
Re: Motor Build
Originally Posted by PanozDuke View Post
Kel,
Mike
Hey Mike, great to hear that the situation has been resolved satisfactorily. Will be interested to see how you go with the exhaust fit up and how it goes power numbers wise. As you will have seen the exhaust performed well again when I streched my engine up to 347.
Select your muffler/s carefully though Mike as I have noticed my car has quite a bit more "bark" to it now with the 347. If I have problems with breaking the 95db rule I may look at using 2 3" Spintech mufflers and merging after these into a single 4" pipe. I have used Spintechs before and they are compact and really kill noise well.
Kel.
Kel M
Panoz GTRA #17
New Zealand
