Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-01-2010, 08:47 PM
Cavalier9696's Avatar
Cavalier9696 Cavalier9696 is offline
Send a message via Yahoo to Cavalier9696
Re: Turbo ecu
I e-mailed the guy on e-bay to see if he is sending any. If not I found both on ebay. But if all else fails can't I use a tube of gasket maker? Will I need gaskets for the DP and WG if they don't send any?
Old 02-01-2010, 09:09 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Turbo ecu
You cant use gasket maker, it wont last any time. Yes you will need gaskets on everything. If they dont come with them you will have to order them.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-02-2010, 06:47 AM
Re: Turbo ecu
K got the gaskets for T25 and T3. Am I going to have to change the type of oil IM using now? I been using Valvoline 10-40 since I could drive and never had any problems. Some of my buddies run 5-20 or 5-30 can't remember. What would be best?
Old 02-02-2010, 08:39 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Turbo ecu
It really doesn't matter. I run 5w-30 full synthetic. Really depends on the weather. You probably shouldn't use synthetic though. I have aftermarket cams which 'need' that.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-04-2010, 05:32 PM
Re: Turbo ecu
Yet another question..lol The nimple on the BOV that goes to vacuum line, right now it is closed tight. How far open does it need to be?
Old 02-04-2010, 06:21 PM
david-b's Avatar
Dave is THAT guy
Re: Turbo ecu
I'm confused on what you mean by closed?
75 Monte Carlo
Old 02-04-2010, 07:35 PM
Re: Turbo ecu
Right here. I can turn it till its totally tight or screw it off.
http://i914.photobucket.com/albums/a...400_193200.jpg
Old 02-04-2010, 08:54 PM
david-b's Avatar
Dave is THAT guy
Re: Turbo ecu
Oh that adjusts how stiff/soft the BOV will be. Not sure on those where the right place is. When it's set to stiff, it takes more 'power' to open the valve to blow off. If it's set too stiff, the BOV won't open and then the compressed air will flow back into the turbo causing compressor surge. If it's too soft, it won't hold any boost and be letting off air every chance it gets.
75 Monte Carlo
Old 02-05-2010, 09:49 AM
Re: Turbo ecu
Guess I'll just have to keep hitting the gas till it feels or sounds right. Oh hey would I need high heat paint to paint the turbo?
Old 02-05-2010, 09:55 AM
david-b's Avatar
Dave is THAT guy
Re: Turbo ecu
Start off with a soft setting. Too soft you'll feel it being open at idle. Too hard you'll hear compressor surge. Just some trial and error.
I painted my compressor with high temp paint, but it's peeling off and looking like crap. If you know how, I would say polish it. Or get it ceramic coated. If you paint, make sure it's 100% clean before hand. Maybe do some light sanding too while at it. You can't paint the exhaust side. Will fall off right away.
75 Monte Carlo
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Turbo ecu
Touch the turbo after a few pulls...
DON'T! KIDDING!
You would need some pretty high temp stuff to do it, and I've never seen it look good.
I do hope you're logging your car when you're "hitting the gas" to set things up.
FWIW, TurboXS (garbage) blow off valves adjust with washers by unscrewing the top portion. That nipple needs to be on as tight as it can go, and the vacuum line should be zip tied to it.
What MAF are you running with that vented valve?
Kris
2012 Genesis Coupe 2.0t
Old 02-05-2010, 10:11 AM
Re: Turbo ecu
Ya I already wiped it down with just a wet rag and got all the grime off, looks better than it did. Wonder if crome polish would work? Believe IM just running a MAP.
Old 02-05-2010, 10:38 AM
david-b's Avatar
Dave is THAT guy
Re: Turbo ecu
Hell touch the turbo after it's been idling... my arms are full of burns from these things. No fun.
Lando, it's the 420a platform, so no MAF, just the MAP.
75 Monte Carlo
Old 02-05-2010, 10:45 AM
Re: Turbo ecu
Damnit. Foiled again.
Kris
Old 02-05-2010, 04:30 PM
Re: Turbo ecu
When hooking up the Oil feed line, I just run it to a new hole in the oil pan oil lvl high? Or anyone got the mesurments to high the line goes on the oil pan? And where do I tap into the block for the oil feed line for turbo?
Oh dave can u send me the link again to that custom made 420 DP please.
1995 Eclipse RS 5psi
Garret T3/T4 Turbo, Procharger FMU, TurboXS BOV, OBX Evolution 35mm External WG, HKS Intercooler, Apexi DP, Apexi exhaust.
