Old 01-24-2010, 10:52 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Just a random Question???
Yea check for speed sensors on the wheels, its probably one of those. For the SRS light the control module should be under the console, you can just lift the cup holder tray out and you should be able to see it, check and make sure that its plugged up first off and no wire are damaged going to it. Remember that with the SRS light on the air bags WILL NOT deploy. Try pulling the battery cables off for 30 min or so to reset the system.
http://www.dsmtuners.com/forums/arti...ble-codes.html
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-25-2010, 06:14 AM
95eagle_talon 95eagle_talon is offline
Ok will do and im going to get my compression tester from work and try and get a compression test done some tim this week.
Old 01-26-2010, 03:16 PM
well guys its leakin oil and puffin out blue smoke so i know its buring oil. Also its idling funny like when i crank it up its revs up to about 4500 rpm dont know what that would be????
Also put new plugs in it lastnight and it was idleing at about 850 and the skpping still didnt go away and then this morning it started idleing at about 4500rpm.
Old 01-26-2010, 03:50 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Check the TPS and the IAC on the throttle body. The IAC (idle air control) adjusts how much air comes in at idle based on all the conditions. The TPS (throttle position sensor) see's where the throttle is at and adds fuel when throttle gets opened up. There's ways to check both sensors.
I would personally pull off the throttle body (2 13mm bolts) and clean it with TB cleaner and check the sensors while it's off. The butterfly plate will stick if it's dirty and may be allowing extra air at startup to come in.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-26-2010, 04:07 PM
ok wil do now.
Old 01-26-2010, 04:41 PM
OK i took it off and it was pretty didrty with a bunch of gunk so im putting it back together and i was wondering if the TP sensor has to be twisted back into place???
Old 01-26-2010, 05:20 PM
Cleand it out and cleaned the iac and put it all back together and it still doing the same thing.
Old 01-26-2010, 05:21 PM
i Think the MAP sensor is bad
Old 01-26-2010, 06:18 PM
Holset powered 420a
The only thing that makes a motor rev up is air. So somehow more air is getting into the motor than it should be. This could either be caused by a vac leak or the IAC opening up for some reason. If the map is bad you should have a CEL. Does the car ever idle down or does it stay at 4500 all the time now?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-26-2010, 06:20 PM
just stays at 4500 and after i cleaned the gunk off the iac the rpms jumped from 1500 to 2500 for about 5 mins the back to 4500 and thats what its doing everytime i crank it now.
Old 01-26-2010, 06:36 PM
Holset powered 420a
Try unpluging the IAC. If the MAP is bad and the ECU is opening the IAC for some reason when you unplug it, it should at least make the idle stable
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-26-2010, 07:39 PM
I tried it. Unpluged the iac and tried it and it did the same thing then tried the TP sensor and it did the same thing then unpluged both at same time and tried to crank it and it still did the sae thing. Then tried it with the MAP sensor and it wouldnt crank with or without the TP and IAC plugged or unplugged.
Old 01-26-2010, 10:44 PM
Holset powered 420a
Well it needs the TPS and map to run. The IAC just adjust the idle so it doesn't need that. Another thing you can try is to put your hand over the TB and see if the car tries to stall. If there are not leaks in your manifold/vac lines when you cover the TB the car should starve for air. If it doesn't then you have a leak.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-27-2010, 06:16 AM
So i put my hand over the TB and it there are no leaks the car should stall?
Old 01-27-2010, 09:48 AM
david-b's Avatar
Dave is THAT guy
Correct. Air should not be entering from anywhere else beside the TB, so if you put your hand over it, you're blocking all air coming in and should stall out the car. If it doesn't, then as Silvr said, you have a leak in in the IM or a vacuum line.
75 Monte Carlo
