| Latest | 0 Rplys |
| Off-Topic Talk about anything other than cars. |
Show Printable Version | Email this Page |
#31 | |
Re: New turbo from the junkyard
That may work, I was just trying to let you know you may have another option.
I was wrong with the part numbers they were 350086 and 350087
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
#32 | |
Holset powered 420a
I see what your saying. I will have to look into that some. If I do put master in there with a longer stoke the pedal will end up being moved up higher to push more fluid. Which may work also but Ill have to do some calculations to see if it would be enough to release the clutch. The stock slave now moves ~.350", I need ~.500". So its a good bit more. But its deffinately worth looking into. Thanks man
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
#33 | ||
Exactly. The pedal on my GST is soo much better than my spyder, and the only really thing I can contribute that to is the difference in the master's since the rest of the setups on the cars are basically the same. I am going to get a used Turbo master cylinder, put new seals in it, and put it in my Spyder, I really think that will fix my drag problem.
#34 | |
Dave is THAT guy
Any chance on getting all this stuff figured out by this weekend? My clutch isn't fully right so was going to rebleed, but then thinking just to replace the slave since I'm in there. I'm personally fine with a heavy pedal as I know where it's at.
VG... do you remember what sizes the fittings are to replace to SS? I've got a ton of SS line and may as well swap that out too while I'm in there.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
#35 | |
Holset powered 420a
Dave you dont need to worry about using a different master/slave cylinder. If yours isint releasing all the way you probably have air in the line and it needs to be rebleed like you said. Upgrading to the SS line is also a good idea. At one point when my car got hot the clutch line would expand under pressure and the clutch would no release. So if the master/slave or line haven't been replaced recently it could be any of those. Hopefully bleeding will take care of the problem tho. Now for fittings on the clutch line I think you are better off buying one. I think mine was like $20, the clutch line uses a flare fitting and a banjo on the slave.
#36 | |
Yea I just bought the stainless line kit off extremepsi. Its for a GST though. On my red car I just replaced the rubber section with stainless. But on my grey car I replaced from the master to the slave in stainless.
#37 | |
My car already had the ACT2600 so the pedal was already a bit stiff. But when I replaced the slave and master cylinder, also installed ss clutch line, the pedal was a lot like a brake pedal. This one time I drove my buddies v6 Sebring w/ a 5 speed. I thought there was something wrong with his clutch because it was like pushing in the gas pedal, felt like nothing was there. I drove his car for the weekend because he wasn't use to driving in busy traffic and we were going to a concert that weekend. The day we got back, I hoped in my car and I thought something was wrong with my clutch pedal because of all the resistance I had forgot about.
^not really relevant but hey, thought I'd share anyway. Didn't proof read either so hope you had fun |
