Old 12-12-2009, 04:40 PM   #31
stainlesssteel
stainlesssteel's Avatar
Re: Ferrari F-40 "Beurlys" spider, scale 1/8
It looks...
Sorry I'm speechless...
Amazing attention to details and execution! Keep us posted on this one!
stainlesssteel is offline   Reply With Quote
Old 02-03-2010, 07:00 AM   #32
Pascal D
It's been a while, but here a little update :
The doors have been coverd with self-adhesive kevlar stickers, and a coat of Tamiya smoke was brushed over them :
It looks a bit "dirty", but that's what the real thing looks like :
To make the screws invisible, I "wrapped" them in plastic. A couple pieces of plasticard, and they're no longer visible :
Greetings
"Wet Sellery"
Pascal D is offline   Reply With Quote
Old 02-03-2010, 06:24 PM   #33
da_ashman
da_ashman's Avatar
Very Nice, I like the dirty Kevlar look. Are those Self adhesive Kevlar stickers part of the kit?
da_ashman is offline   Reply With Quote
Old 02-04-2010, 08:42 AM   #34
Pascal D
I found the self adhesive kevlar and carbon stickers on the internet a couple of years ago (I think they came from scaledetails, but I'm not sure).
The Pocher kit has a lot of parts, but it lacks the "nicer stuff" such as kevlar and carbon decals / stickers, heat-shield foil, mesh, brass bolts and nuts, etc.
Greetings
Pascal
Old 04-20-2010, 06:08 PM   #35
Pascal D
It's been a while since my last update, and there's little progress, but here are some pics :
Both doors have received their kevlar/carbon stickers and a coat of tamiya smoke :
Then the inside of the doors were glued with 2-component glue :
And I started the first session of filling and sanding to get rid of the F-40 logo :
The gaps in the doors were filled :
It took many hours to fill the gaps, but finally it starts to look good :
The seats are a different story, the OMP version is quite different from the original F-40 seat :
After my first try to make the sides of the interior wider, I found that they're still not wide enough :
The picture gives an idea just how wide they are :
Started cutting an sawing to alter the seats :
But it will take a lot more work to make them look like the OMP ones :
Old 04-20-2010, 06:18 PM   #36
Pascal D
But first it was time to widen the sidewalls. I put a couple of cardboard strips on the floor, just to get an idea how wide the sidewalls will become :
Made a template from cardboard :
An took a piece of transparent plastic to make the new sidewalls. I used this type of plastic because it is 2 mm thick and very strong :
The "fire-wall" got some attention :
The fire-wall will be covered by plastic plates, but this will be done when the sidewalls are finished :
Glued the parts in place, and now it's time to widen the front part of the interior :
Jees, sometimes I wonder what I got myself into. I figured that the model would be completed in a year or two. But with this amount of work (and at the slow rate of progress), it will take a lot longer.
But I'm still enjoying this build an hoping that it will turn into a helluva model
Greetings
Pascal
Old 04-20-2010, 08:35 PM   #37
da_ashman
da_ashman's Avatar
Oh itll be one Hell of a model when finished!!!! Looks amazing!!! Lego comes in handy so often!!
Old 04-22-2010, 11:53 AM   #38
f40
This will be One Hell of a beautiful replica. Your building skills are unbelievable. This project may be alot of work, but Im shure the end results will be worth all your efforts.
f40 is offline   Reply With Quote
Old 04-26-2010, 02:57 PM   #39
rx7king
rx7king's Avatar
unfortunatly almost all of the pics in the beggining dont work, cool build tho
rx7king is offline   Reply With Quote
Old 05-05-2010, 05:17 AM   #40
Pascal D
Yes, something went wrong with the forum that hosts the pics. As soon as I get a chance, I'll put them back in this thread.
I finally found a way to keep the sides of the body together in the correct position. And I did some work on the insides of the interior :
It looks a bit strange, but when the interior is finished, the steel rod will be hidden from view.
Greetings
Pascal
Old 05-05-2010, 08:24 PM   #41
da_ashman
da_ashman's Avatar
Nice work, how many sheets of styrene have you been through?
Old 05-29-2010, 03:23 AM   #42
Pascal D
Sofar, I've used 4 sheets (A4) of plasticard.
A little update :
The front end of the interior is "boxed in" :
A dryfit shows where the dashboard will be installed :
The rear end of the interior will get an aluminium plate (1mm thick). This will make it smooth and makes a nice reinforcement for the fragile plastic :
And I added a large plate of aluminium ( 2mm) to the front part of the chassis, this prevents the plastic from bending, and will be used to attach the front suspension :
Greetings
Pascal
Old 10-15-2010, 07:04 PM   #43
Pascal D
This car has no "rear-framework" to hold the engine / gearbox, so I had to made one myself.
I took a piece of 2 cm thick transparent nylon, and used my Dremel and a saw to get it in to the right shape. (I have no idea what the framework looks like on the real Beurlys, but it doesn't matter because it won't be visible afterwards) :
The original Pocher model has 4 holes to attach the rear framework to the floorplate :
A dryfit with the (not finished) firewall :
The engine and gearbox will be fixed to a strong steel rod, that runs through the entire length of the car :
Two brass tubes will hold the engine mounts :
And maybe I'll add some more brass tubes to make it stronger :
Greetings
Wet Sellery
Old 01-15-2011, 04:56 PM   #44
Pascal D
It's been a while, but here's an update. I'll let the pictures speak for themselves :
Yours sincerely
Pascal
Old 01-15-2011, 08:42 PM   #45
cinqster
cinqster's Avatar
Woooooooo..nice to see you back on it Pascal...looking good mate! :o)
cinqster is offline   Reply With Quote
