Old 10-30-2012, 06:48 AM
Johnhartz Johnhartz is offline
Re: AC compressor replacement on 2001 Taurus/Vulcan
Originally Posted by shorod View Post
Are you referring to evacuating and recharging the system? If so, you're right, there is more to it. Evacuating the system requires specialized equipment to properly recover the existing refrigerant as it is illegal to intentionally release the R-134a in to the atmosphere. Likewise specialized equipment is require to properly recharge the system and fill with the proper amount of oil and R-134a. You're going to need to visit a shop that does A/C work for that, but quite honestly that's probably your best approach at this point anyway. It's possible that all you really need is a new pulley and/or clutch/field coil assembly rather than a new compressor. An honest, experienced shop will be able to make that determination for you, and if the compressor is shot, will be able to evacuate the system in order for the compressor to be replaced as well.
-Rod
Okay Thank you Rod, yes hoping it's just the pulley and clutch at this point. After looking at it looks like the plate is broken so might have to do the entire compressor.
Old 10-30-2012, 08:12 AM
Hey do you have a PDF you send me for the compressor or the pulley/ clutch? It would be of great help! Thank you!
Old 10-30-2012, 12:20 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Is your Taurus also a 2001 with the Vulcan engine?
-Rod
Old 10-30-2012, 12:50 PM
-Rod
Yes it is I took your advice and had someone authorized to release the ac do it.
It wont hurt to send over the pdf for the future. Thank you!
Old 10-31-2012, 07:04 AM
shorod's Avatar
SHO No Mo
I attempted to send the files to you at the address provided a few posts back and the email was bounced. Please send me a Private Message with the correct e-mail address.
-Rod
Old 10-31-2012, 07:42 AM
-Rod
You can send it to [email protected]
Thank you
Old 11-06-2012, 03:51 PM
Tinovolpe Tinovolpe is offline
I just replaced the compressor and drier on my 2001 3.0 duratec not long ago. Was proud of myself for being able to do it. A lot to take apart but if you take your time you can do it. I used up most of a 3 day holiday weekend to do it.
I was als able to get a used copy of the service manual (2 volumes!) from Faxonautolit.com. They seem to have a lot of manuals there. Also picked up the one for my 99 Durango. I looked at them and them proceeded to throw away my Haynes and Chilton Manuals. Their useless in comparison. These are the real deal.
Good luck
Old 02-28-2013, 02:53 PM
miller2002us miller2002us is offline
can someone please send me the pdf file that i would need as we are replacing the whole a/c unit on a 2001 ford taurus
Old 02-28-2013, 09:32 PM
shorod's Avatar
SHO No Mo
Please confirm that you are working on a Vulcan engine versus the Duratech.
-Rod
Old 03-01-2013, 01:06 PM
I do not know, how do I find out which it is?
Old 03-01-2013, 10:10 PM
shorod's Avatar
SHO No Mo
If it has the 24V DOHC engine it is the Duratech.
-Rod
Old 03-02-2013, 03:39 AM
no it is not the duratech then
Old 03-02-2013, 10:49 AM
shorod's Avatar
SHO No Mo
If you send me a private message with an e-mail address for you, I can send you a PDF of the procedures to replace the compressor for your 2001 Vulcan Taurus. When you say "the whole A/C unit" are you meaning just the compressor, clutch and field coil, or are you also referring tot he evaporator core, condenser, drier, orifice tube, etc?
-Rod
Old 08-03-2014, 05:14 AM
10thwardziggy 10thwardziggy is offline
Hello i have a 2002 ford taurus se and i wanted to kno can I bypass my AC compressor pully without taking it out using a shorter serpentine belt?
Old 08-03-2014, 04:23 PM
shorod's Avatar
SHO No Mo
Someone recently posted about this with a part number. They mentioned the belt will end up running the ribbed side on a non-ribbed pulley though which is somewhat less than ideal. Check some of the fairly recent posts. If you don't find it, let me know and I'll do some digging.
-Rod
