Old 08-28-2009, 08:56 PM
12Ounce 12Ounce is offline
Re: 99 Windstar ticking
Good news! Please try to keep rainstorms out of your engine internals, hereafter. (LOL)
Old 11-02-2009, 08:35 PM
SlimJimRD SlimJimRD is offline
Well the noise has not come back, thanks 12Ounce.
Now the problem is misfire. Ran B -12 thru the gas tank and the engine seemed to have misfire, then went away after a couple hour trip. It is now back and has CEL showing misfire on cylinder 3 and 5. I replaced the plugs and wire about 33,000 miles ago when changing the isolator bolts. Should I try another injector treatment, change all the plugs and/or wires? Coil, can it be checked?
Just not sure how to diagnose this issue.
Steve
Old 11-03-2009, 09:31 AM
Since #3 and #5 are NOT on the same coil in the pack, it makes me guess something other than the pack is involved. Just the same, I would remove the pack ... clean and inspect it ... remove the plugs and cables and give everything a close check ... looking for high voltage tracks, etc.
Did you ever do a compression test?
Old 11-03-2009, 11:55 AM
I never did the compression test?
Should I as I found my old gauge that you just hold in the cylinder.
Old 11-03-2009, 12:18 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
To do the compression test, open the throttle body and rotate your engine. It's a good idea to test these 2 cylinders.
When you remove the plug, check if there's oil deposit on it. If it's the case, don't replace the plug, but find the cause of the oil presence.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 11-03-2009, 03:07 PM
That type gauge works ... but it is more difficult and usually requires a helper. I think screw-in gauges are part of AutoZones loaner-tool program ... but don't hold me to that. I bought mine for less than $30.
Old 11-03-2009, 04:23 PM
Do I need to rotate the engine by hand or can I use the starter when doing the compression test?
Old 11-03-2009, 05:36 PM
yes, you need to rotate it by hand, with a breaker bar.
Old 11-03-2009, 08:41 PM
I would initially turn it by hand after the plugs are out ... just to make sure its free. But I always use the starter for compression testing. Crank it 'til the gauge needle peaks out.
BTW, don't try the test unless all plugs are out ... too much load on the starter.
Old 11-03-2009, 09:26 PM
Ok, you can use the starter. I recommend you also to disable the fuel pump, and also that the engine is hot when you do the test.
Pressure should be between 100-150 psi.
Old 11-04-2009, 11:50 AM
So should I just pull fuse 5 under the hood to disable the fuel pump before testing?
Old 11-04-2009, 11:59 AM
exactly
Old 11-04-2009, 12:25 PM
Don't forget to check how the plugs are connected before disconnect them.
Old 11-29-2009, 02:12 PM
Finally got around to test the cylinders.
Here is what I have for compression which I think is okay.
Cylinder 1 - 3
140 120 120
Cylinder 4 - 6
140 135 135
I did not see and high voltage tracks on the wires.
Here is a picture of the plugs which I think all look okay.
Any thoughts on what else to try and I will try and go clean the coil pack now.
Old 11-29-2009, 03:46 PM
So I took the coil out and one of the corners is cracked on the black plastic, closest to coil #6. Should I go ahead and replace it?
Tags
lifter , ticking
