| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#31 | |
Re: Lower and upper intake manifold gasket, help!
what is the saying again? oh yeah...if it aint broken dont fix it
#32 | ||
I didn't realize it was Tim who asked the question about changing the water pump. I thought it was Unknown7 (the one who started the thread) I was just thinking of HIS inexperience with the mechanics so if he changed it now, while already in there, he wouldn't have to take it all apart again IF it failed in the near future. Plus IIRC his car has almost 200k on it.I don't know anything about Tim's car. (My bad!!!) |
#33 | |
In God We Trust
No worries. I shouldn't have hijacked this thread. My Bad.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
#34 | |
![]() Join Date: Jan 2005
#35 | ||
In God We Trust
I've never seen anything like it guys, I bought the car almost 3 years ago with 70,000 miles on it. It actually came from kansas and didnt have a spec of rust on it or under it. 3 Years later being drive through 3 Minnesota winters, Its started to cancer out above the passenger rear wheel well. Not to mention the supbrame, my calipers, and rotors are all that ugly rust color.
#36 | ||
![]() ![]() Raybestos AT Rear Rotor
#37 | |
In God We Trust
BOB, I CANT BELEIVE IT!
I was going to do my breaks again this summer becuase of a slight pulsation and heavy rust on the rotors. I was just going to ask if there where any brands of rotors that come like the one you have pictured above. You just saved me a question.... Are they spendy? I was thinking about painting my calipers at the same time (black or silver).
#38 | ||
97 Grand Prix GT 360,000 miles as of 02-01-09 391 000 miles as of 11-17-11 400,000 miles as of 3-15-13 01 Duramax/Allison 07 G6 convertible |
#39 | |
In God We Trust
IThe 3800 waterpump isnt in such a bad spot. I have seen a lot worse (OHC motors where the pump is driven off the timing belt). But it sure isnt as easy to access as the 3100. (GM did get something right on that motor) I shouldn't be so cruel.
#40 | |
When I did my water pump on my 3800 GP it took me 2 days to get it back together. Was having a lot of trouble getting the power steering mounting screw back in. Beside my hands are big so I skin my knuckles all the time.
#41 | |
I figured out how to do it after I had taken the power steering pump off. Take one bolt out and loosen the other and let the pump shift over. That was my biggest problem when I did mine.
#42 | ||
![]() Back to the subject of water pumps. On some of these replies it goes to show you that some people are their own problem when doing DIY work. I wonder how many actually torqued the pump down correctly as I mentioned in my prior replies.When you have a water pump failure obviously you replace it and I have no issues with that. Replacing known good parts capriciously and arbitrarily is what I do not agree with. If we were to accept and apply that theory as good maintenance practice then we are all in trouble or time to sell it or trade it in. That is all I have to say. The rest of you can continue to ramble on. ![]()
#43 | |
stupidity should hurt
![]() Join Date: Aug 2004
Just to clarify, when I mentioned replacing the water pump, I assumed Tim inspected it and it was questionable. I do agree with Bob that you don't just change parts if there is no evidence to support doing so.
That being said, I have seen twice where a water pump with just a couple of thousandths free play on the pulley that wasn't leaking or making noise failed immediately after a UIM job, probably due to it being the weak link in a now sealed and properly pressurized cooling system. That is why I originally suggested changing it.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
#44 | |
![]() Join Date: Aug 2008
sorry this an old post, but I finally got to doing the job, the gaskets were indeed shot, and I almost lost a socket in the air intake, but almost everything went well. however when I start the car, it has a really lumpy idle like it jerks the car. It seems like a misfire, and I'm 99.9% positive I hooked the spark plugs right. however I ended up losing some egr/evap hoses. could that cause it? Any body have any suggestions?
#45 | |
Losing hoses? You mean broken or missing? That could cause a vacuum leak which could cause a poor idle and other issues. Get 'em replaced as soon as possible.
And double check the ignition wires and make sure they go to the right cylinders from the coils. Firing order SII 3800 engine: 1-6-5-4-3-2 Front bank, left to right 1, 3, 5 Rear bank, left to right 2, 4, 6. Coils: top coil: 6/3 Middle coil: 2/5 Bottom coil: 4/1
