Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 12-22-2008, 02:17 PM   #31
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 98 Jimmy stuck in 4WD - Can't go to 2HI
Originally Posted by loots42
Without grounding pin 13, yes
Yes
And the try it grounding pin 13.
http://www.troublecodes.net/OBD2/
MT
MT-2500 is offline   Reply With Quote
Old 12-22-2008, 02:44 PM   #32
loots42
With grounding 13, no lights on the 4WD selector illuminator, nor blink
loots42 is offline   Reply With Quote
Old 12-22-2008, 03:43 PM   #33
MT-2500
AF - Advisor
MT-2500's Avatar
With grounding 13, not lights on the 4WD selector illuminator, nor blink
What do they do if you do not ground it?
Does all button lights come on for a bulb check and the go out when key is turned on?
MT
Old 12-22-2008, 04:20 PM   #34
loots42
Yes, when I turn it on, all lights, dash and 4wd selector go on. Then when I start it up, the dash lights go off, and the proper 4wd switch light is illuminated.
Old 12-22-2008, 05:27 PM   #35
MT-2500
AF - Advisor
MT-2500's Avatar
The key question is
Does all 4W buttons light up for the key on bulb check and then go out and then show you what gear it is in?
You need to get some good repair info on it like a factory repair manual or the all data on line sub for one year one car sub. about 26.95$ usa plastic.
http://www.alldata.com/products/diy/index.html
The all data on line sub will take you step by step threw the testing process.
Good luck
MT
Old 12-22-2008, 10:31 PM   #36
loots42
Yes, all the 3 lights (2H,4H4L) light up momentarily, then 2 of the 3 go out. It is left showing which range the truck is in.
Old 12-23-2008, 11:07 AM   #37
MT-2500
AF - Advisor
MT-2500's Avatar
Ok.
If the lights do not come on for bulb check with pin 13 grounded.
You need to get the All Data sub and go threw the repair flow chart for that problem.
It will led you threw the repair step by step.
Good Luck
MT
Old 12-23-2008, 09:12 PM   #38
loots42
Ok, after grounding pin 13, all lights go on momentarily, then go out and none come back on. So no code is thrown.
I did discover that when stuck in 4wd, if I repeatedly, and quickly shift back and forth from 4Hi to 4Lo, it will jump into 2H.
Old 12-24-2008, 10:24 AM   #39
MT-2500
AF - Advisor
MT-2500's Avatar
MT
Old 12-31-2008, 08:27 AM   #40
loots42
I subscribed to alldata.com. It did not have a use case for the problem I had.
I suspected it was the encoder motor, but started with the TCCM from a junkyard for $50. That wasn't it. So I bought a rebuilt encoder motor ($125)and now if shifts beautifully.
Old 12-31-2008, 10:31 AM   #41
MT-2500
AF - Advisor
MT-2500's Avatar
Thanks for posting back the fix.
Glad you got it fixed.
The All data should have all of the repair flow charts and test for it.
It is the same as factory repair manual.
But sometimes the info is hard to find in there.
If you can not find the info contact all data and they will help you find it or send the info to you.
They are very good at helping you.
Good Luck
MT
