#31
Re: Engine Swap
Thanks to everyone who has been helping me on this. Do you know someone who might have the instructions for converting obdo to obd1 a diagram, color scheme with instructions or a script that I can follow for the wiring. What is wrong with buying a conversion kit from ebay? Am I supposed to use the wiring on the d16z6 injectors on with the dx harness is this correct. I would like to get all my questions answered on one page thats all.
#32
Re: Engine Swap
The reason why we've asked you to contact the person you bought it from is because each harness is going to use different color codes. You need the diagram from the guy you bought it from if you want the correct color codes.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete) www.naytontech.com :: youtube.com/naytontech |
#33
Re: Engine Swap
and some things shuoldn't be bought on ebay...i just had a bad experience with Rywire (took 3 weeks to send my part) buy i bought an obd0 to obd1 harness from Blue Ridge Motorsports...i paid $75 overnighted to me (mostly b/c i'm a couple hours from them)
Blueridge Motorsports Morganton, NC 28655 828.433.4545 PH. 828.433.4501 FAX www.BlueridgeMotorsports.com
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
#34
Re: Engine Swap
Ok, here you go:
On the D16Z6 Engine harness, you are going to harvest the complete fuel injector wiring, including the little plug with all the yellow/black wires on it. Just unloom the thing with a razor and pull this wiring out. Its relatively simple. You will also want to get the plug for the Vtec-2 plugs there: 1 1 wire plug 1 2 wire plug. And you will need to get the plug for the o2 sensor, its a 4 wire plug. Who ever is doing this swap will end up adding these wires and plugs into your stock harness. Doesn't matter what swap you are doing, you always stick with your stock engine harness and just modify it however you need to. The problem with buying a conversion harness off ebay is this right here: You have no idea what color wires go to what. I can give you Boomslang's instructions, but I don't think it will really help you on wire colors. It will help you understand more of what you need to do on the OBD0-OBD1 swap though. Simply go to www.boomslang.us and click Resources. This is the harness I got and it was excellent, great instructions, well made and no issues anywhere on it. It was a little pricier than others, but something as important as my ECU, I'll spend the extra cash.
Tony 91 Civic Sedan DX - Stock 287k Miles |
#35
Re: Engine Swap
Also, I have already told you once, don't make new threads asking the same questions you are asking in here. It helps no one when you do that because they won't see what else is going on.
#36
Re: Engine Swap
Tony,
Do I need a resistor box? Im not sure if the d16z6 are high impedance injectors. I was told that I wouldn't need one. Last edited by fmercado19; 11-02-2008 at 01:53 PM. |
#37
Re: Engine Swap
You wont.
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
#38
Re: Engine Swap
NO if:
Honda-free since early 2009.Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win. |
#39
Re: Engine Swap
Where can I buy a really good conversion harness with instructions?
#40
Re: Engine Swap
i got mine for $75 shipped and it arrived the next day (i'm like 3hrs from them so it may be different for you) and also try www.Rywire.com they took 3 weeks to ship my distributor harness though
#41
Re: Engine Swap
Boomslang is a great harness as well, its the harness I have for mine, well made and great instructions, it will answer all your questions.
#42
Re: Engine Swap
Where can i find a b16a3 intake manifold and a ecu ecm p30-000 ive looked everywhere. Does anyone know someone that might have these parts for sale if so please reply.
#43
Re: Engine Swap
why do you necessarily need an a3 im? search the market place over on H-T yet?
#44
Re: Engine Swap
does anyone know where i can find a b16a3 intake manifold and a ecu ecm p30-000 i need them for the referee.
#45
Re: Engine Swap
Does anyone have or know someone who might have a 95' del sol b16a3 intake manifold and a ecu ecm p30-000 for sale. please reply.
