Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 10-28-2008, 02:23 PM
eric1h eric1h is offline
Re: Turning in my man card... I want to make the GTRA quieter... best method?
Originally Posted by NZGTRA17
The system I built for my car over here in New Zealand takes the LH exhaust up over the top of the clutch bellhousing and merges it with the right down at the bottom of the firewall on the RH side of the car. Very much the same as a Trans Am exhaust system.
Dont have a web site to post pics to so if someone wants to post them to their web and onto this site I will send pics of the completed system for posting.
shoot me an email and I will hook you up with some space to put some pics up, or email them to me
eric @ esomail dot com
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 10-28-2008, 03:49 PM
NZGTRA17 NZGTRA17 is offline
Pics of completed exhaust;
Finished outlet after panneling Up;
Outlet prior to Coating;
Right Hand Side:
Start Point:
Old 10-28-2008, 03:59 PM
carhauler carhauler is offline
Why all the work converting to a single exhaust? The exhaust looks too low to the ground. I'd think you'd bottom out when loading onto a trailer. Maybe I'm missing something here.
Carhauler
GTS #40
Old 10-28-2008, 04:02 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
HOLY CRAP!!! That's amazing work... did you make that yourself? I want that
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 10-28-2008, 04:04 PM
it is BEA U TI FULL work, but sure seems like a lot of work for its intended purpose.
That is one sexy motor!
One earplug in the drivers ear... DONE! :-D
Old 10-28-2008, 04:07 PM
Exhaust is no lower than standard car. Standard car exhaust has been proven to be to restrictive for even mildly modified 5.0 engines (anywhere over 280hp at wheels). Single exhaust allows far better tuning possibilities as well as taking the noise away from the drivers side which is very important regards driver fatigue for endurance racing (my apllication).
I will probably start a war of words on this one, but here goes...............I thought the cars sounded terrible with the dual exhaust (without a balance pipe between the pipes). A flat horrible resonaty noise with no go to back it up!!
Cobra4B's Avatar
^ I believe he's during endurance racing in the car so keeping heat/noise away from the driver are important.
Brian B.
Old 10-28-2008, 04:08 PM
Cobra4B's Avatar
So did you fab that up yourself?
Old 10-28-2008, 04:09 PM
Brian, yes all fabricated at home. A mate lent me a TIG welder so managed to knock all work out except for coating which was done by local coating shop. I expected the job to take up to 60 hours but cut it out in around 40 - 45 much to the wifes anguish.............you know how that goes!!
Old 10-28-2008, 04:16 PM
Cobra4B's Avatar
Very nice... seeing your car done up w/ a carb makes me excited for our setup as we have "sister" cars.
In reality I'm going to re-do the current exhaust w/ better/quieter mufflers for now. Going to ceramic coat the shorties and fully coat/wrap the sidepipes.
Brian B.
Old 10-28-2008, 04:23 PM
Will take some more shots when car is moved out of shed next Brian. Have the fuel tank out at the moment. On another note we set all the suspension up in the weekend. Weight results were interesting as thought we would have dropped a bit from the claimed 2550lbs (alloy heads, alloy diff head etc). Weighed in at exactly at 2570 lbs (wet but no gas). Good news was that even with me in the car (220lbs), weight was still evenly distributed with near 50/50.
Old 10-28-2008, 04:28 PM
Nice, i swear these cars are heavier than that, My M3 race car weighed in at 2700lbs and i could roll it around very easily and push it onto the lift in the garage.
The panoz feels like a lead sled does not roll nearly as easily.
Cobra4B's Avatar
Interesting... you didn't happen to weigh it before the mods did you? I'm going to weigh it before the motor work and after.
From what I've read on here it seems that the 2550 was about 200lbs off of reality. They're more like 2700-2800lbs.
Brian B.
Old 10-28-2008, 04:29 PM
Cobra4B's Avatar
I wonder how much more weight the 4.6 DOHC costs you? That said it is all aluminum vs. the iron 5.0. Like I said above most people are saying they're really closer to 2800lbs.
It'll be interesting to see what I get out of mine after the swap to aluminum heads and a carb etc.
Brian B.
Old 10-28-2008, 04:31 PM
WOW, never realized the difference!!!
I want to swap in one of these!
http://cgi.ebay.com/ebaymotors/Parts-Accessories_Car-Truck-Parts-Accessories__LS1-5-7-L-GM-350-CHEVROLET-ENGINE-BRAND-NEW_W0QQitemZ110304185967QQddnZPartsQ20Q26Q20Acces soriesQQadiZ2865QQddiZ2811QQadnZCarQ20Q26Q20TruckQ 20PartsQ20Q26Q20AccessoriesQQcmdZViewItem?hash=ite m110304185967&_trksid=p4506.c0.m245&_trkparms=72%3 A836|65%3A12|39%3A1|240%3A1318
