#31
Re: Turn key and no start/crank...bat is good!
PInched wire somewhere, Check all of the grounds on th ignition circuit and check the wire firm the relay to the starter for continuity.
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
#32
the AZ starter may have burned out your starter relay.....new relay may now be damaged..... Last edited by j cAT; 05-23-2008 at 03:13 PM. |
#33
I figured the problem out!
Ok, I am pretty sure I have this problem figured out now. I took the starter back off and took it back to AZ. The whole time I was looking at this starter I could see some pretty obvious arc marks on the ground terminal on the selenoid. I was like what hell you idiot you jumped the wrong terminals...but after thinking it through I was like no fricken way i jumped the wrong ones cuz it wouldn't have cranked then...still puzzled I had AZ test the starter when it dawned on me what caused the arc marks and why it was working until I put everything together and let it off the jack. When I put the heat shield back on, I put it on in the wrong position and it was touching both hot and ground terminals...hence the blown ing fuse, the arc marks, and why the paperclip was getting red hot...duh! This whole sequence seemed to be rolled right in with the existing problems, but in fact I fixed the problem when I replaced the relay and then caused a new problem when putting the heat shield back on.
I did talk AZ into giving me a new starter, after explaining to the master tech several times how auto electric works to blow fuses. He just couldn't understand that a fuse could be blown if power wasn't getting sent back to the fuse. He just couldn't fathum that a big draw in power from it being grounded out would blow a fuse. It was pretty comical and the customers behind me were chuckling at the 101 class I was holding with the master tech. So put the new starter in, carfully place heat shield in right position, replaced ing fuse and "wall-ah" starts right up. This whole time my only problem was the $10 starter relay, not the other $300 dollars in parts and hours of labor I invested. I will have to check back through this thread and see if anyone suggested to check the relay....I hope not else I will have major egg on my face if they did. I thank each and everyone of you that posted to this, it great to have someplace to turn when problems arrise. It seems this is a frequent problem with alot of chevy's and as I was reading other posts on other sites seems to be a major problem in caviliers and impalas...no start/crank. Maybe we could get a sticky somewhere informing these people to change the $10 relay, that seems to be working on and off...usually working when you take it in to get the vehicle looked and not working when you are sitting somewhere else. I read many posts with people having these problems. Again I thank you all, and hope to GOD I am not back here on this thread posting promblems with this no start/crank problem. |
#34
Re: I figured the problem out!
thanks for the feedback....this will hopefully help others take extra care when installing their starters.....also remember to have assistant turn key to crank position and check for voltage at solenoid before replacing starter...also after removing starter check starter with jumper cables before buying new one....loose/corroded connections will cause damage to starter ..
#35
Hey guys i have a chevy silverado 08 that i bought with a bad trasmission. I cranked up when i bought it but ever since i replaced the transmission, now it wont crank. The battery is charged because i got it charged at autozone. When i turn the switch i get radio, lights, ac, everything but it just wony crank, it doesnt even try to start. I have checked fuses and the connection with the starter and everything is on fine. I have tries doing the whole unlocking and locking with the remote and also holding the switch and it wont do. HELP!!
