| N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance. |
#31
Re: turbo
The engine in the teg is a B18B1, and they can handle a good bit more power than any D series engine (talking factory shortblocks here)
#32
Re: turbo
is the rs and ls same engine or they have different engines, which on is better.
#33
Re: turbo
ebay turbo kits are notoriously shitty....dont waste your money. Put it this way: my turbo costs $850, do you think an entire quality setup can be had for less than the price of a turbo?? If yes, then go ahead and find out first hand how well China builds turbo setups
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
#34
Re: turbo
are they all from china on ebay. see i live in canada b.c. and i need to find a turbo kit that is used that is cheap, or one that is on ebay. one more question the blow off valve is the device that makes the air noise when it gets rid of air right.
#35
Re: turbo
Yes the LS/RS/GS all have the same engine from 94-01.
The blow off valve's main function is not to make noise, but to release the air when the throttle plate is suddenly close so it doesn't send a shock wave back to the turbo. The air will try to reverse itself, thats bad for a turbo and can damage it if extreme enough. |
#36
Re: turbo
If you are still deciding which engine is better, the decision goes to the B18a hands down. With that engine you not only get a stronger factory shortblock, but you can also swap on a VTEC head and have yourself a cheap and effective 300whp LS/VTEC for very little money.
#37
Re: turbo
will the engine is a stock 1996 acura integra ls.
PWMAN i know that’s what it does, but is the blow valve the thing that makes the air noise. one more thing is there any way u can adjust the hood of a 1994 Acura Integra, because the hood is higher then the body at the hinges where it connects to the car. The car has no accident but the guy told me you can adjust it, but I just want know if its true. |
#38
Re: turbo
Ummm, if you knew what it does that you'd know the answer to that question
#39
Re: turbo
k i guess that the blow off valve does make that sound
#40
Re: turbo
is it true that a full cat back will make it harder for ur car to pass air care
