Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-16-2007, 02:09 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Turbo a 420A... I Want Your 2Cents
Wait a minute, so I am even more confused... is it 318 whp from an actual dynometer or a DSMlink projection? And holy A/F ratio! 9.21:1??
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-16-2007, 02:18 AM
steviek's Avatar
steviek steviek is offline
no actually did 318 on a dyno. baseline run was 220 with 7 counts of knock.
That a/f ratio is the estimated look at aemwbgauge thats what is actually reading true a/f values which is 10.8:1 The reason my af estimate is off is because my fuel pressure isn't rising 1:1 with boost so I'm having to add fuel flow at the injectors which my dsmlink is accounting for but not realizing my fuel pressure isn't where its supposed to be.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 10-16-2007, 06:30 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I have to say for your setup those are really great numbers.
1991 GSX 2.3 Stroker
Old 10-18-2007, 04:15 PM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
I like where this thread is going. I hate to bring it back to my original post. But I want to get an opinion on whether a fully programmable ECU is necessary. I met this kid and he said he used nothing but a fuel pressure regulator to get 400fwhp and a piggy back would be more than enough... I doubt he did what he said, what do u think? And would a SuperAFC be enough? thanks
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 10-18-2007, 04:39 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
What's a fully programmable ECU? DSMLink is one of those, but there is none for the 420a. MegaSquirt and AEM EMS are standalones, but they still use the actual ECU.
You need someway to control the fuel. A regulator is not enough. You need something to actually the computer to put more where. I forget what you wanted to get, but a SAFC is good for 450cc (IIRC) injectors. With a ton of boost and anything larger, you need something else. For a straight build with the E16G running like 15psi, the SAFC should be good enough.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-18-2007, 09:05 PM
Kuhn's Avatar
I think this one works... What about AEM's Standalone? http://www.titanmotorsports.com/aemstanecu.html I've never tried it, so it might be way above what I'm trying to do.
'98 Eclipse RS
Old 10-18-2007, 09:32 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Deffinately go with megasquirt. Its full stand alone for fuel and spark. You actually can take out your stock ecu, but it controls more than just the motor so most leave it in.
If your friend was running something like emanage and running a 8-injector setup it is deffinately possible. It would be almost impossible to get 400whp using a SAFC, they just dont have enough adjustability.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
