| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
#31
Re: Difference between turbos
Well I have noticed that the evo 3 makes full boost extremely quickly it seems to me like its either full on or full off. If I try to keep low by peddling the throttle it just fluctuates up and down tremendously depending on whether I am laying off or putting down on the pedal. I wouldn't be too worried about breaking traction up in the higher gears with it but first and second may be a problem the spool up time on my car with a 3' turboback and the rest of my mods is like nothing It is almost identicle to the t-25 just way more top end power... On the other hand I'm pretty sure the big 16g will act quite similarly but I have no experience with it.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
#32
maybe i should stick to the fp green then? i just cant stand the high end (or lack their of : ) with the t-25... and dont have the money for the green, not to mention, its WAY overkill...is their a way to tell the difference between the Evo3 16g and Big 16g visually without pulling the compressor housing off? i'm shopping around right now and see TONS of EVOIII Big 16g's but their is no such turbo, its eaither a Big 16g, or an EVOIII 16g, so is their something visually different? |
#33
http://www.extremepsi.com/store/cust...cat=426&page=1 http://www.extremepsi.com/store/cust...cat=426&page=1 edit how will going with a fp green which delivers more power save you from burning out because you may not loose traction right away when it starts to spool but you will sure as hell lose it when it hits full boost I guess I'm just saying its a matter of time... also people probably just say "big" in the title so it gets more hits or something, its redundant I know but it means nothing it will be just the regular evo3.
#34
Edit: Quote:
#35
and no man they really are different colours im 98% sure I think the material change is one of the reasons the evo3 is lighter.
#36
and awesome, so the evo3 has a lighter color compressor (cold side) housing then the B16g? correct? thats GREAT news! |
#37
Have you done any traction mods to help with the burning out? Going with the FP Green will only make matters worse once full boost hits, you'll be burning them all the way through 3rd and into 4th instead of 1st and 2nd, plus only using half of the turbo? That's a complete waste of money IMHO.
Get the EvoIII, then some traction upgrades, and THEN see where you're sitting as to where you should go next. |
#38
Man I missed a lot here...but I remember talking to a guy on the phone at RRE and he said the differance between the Big 16G and the EVO 3 was mainly in the hot side...it is a little bigger I think he said and it is made of a slightly differant metal and is lighter than the regular 16G
1998 Eclipse GSX 6 Bolt swap MHI Big 16g FP Race Manifold Apex'i N1 Cat-back Apex'i N1 Downpipe Walbro 255 fuel pump GReddy Type S BOV Turbo XS Boost Controller Balance Shaft Elimininator ACT 2600 RRE 11lb No Name Flywheel Prothane Motor Mounts Tokico Illuminas Advanced Handling Kit RRE Front and Rear strut tower bars RMDSM Front and Rear Sway Bars TRE Stage 2 Tranny ARP Head Studs, Main Studs, Rod bolts |
#40
for more info!
#41
20g it up! Screw messing with all that 16g crap. You can make 400 ponies on the 20g and have a little room for some more at a later time.
1991 GSX 2.3 Stroker |
#42
well i was thinking about getting the 16g, then making my own "bastered 20g" that slowboyracing makes. but i need to know what core they use. also, the compressor cover on the Evo3 is thinner/lighter then the b16g, and i dont know of the 20g blades will fit into the evo3 housing as opposed to the b16g... anyone?
#43
I think you're gonna get in over your head with tearing down these turbos. Just buy the one you want, instead of throwing a bunch of different parts together, because the chances of it working correctly for a long time are slim-to-none. First time turbo rebuilders always tend to screw something up.
#44
I agree with gthompson97.
But I think you should look at it from a more realistic stand point. Not saying that the 16g doesn't make good power. For what your power goals seem to be, I think the 20g would be more a proper fit. The 20g can make about 380-400 easy with proper mods and a good tune. To do that with a 16g evo 3 or not is gonna require a significant amount of tuning and tweaking your setup as was said above. If you really have your heart set on the big 16g than go for it, just know that anything over 350 is really not very realistic for the turbo. Crap 350 is pretty good for that turbo. I just looked at tuners and I see only two or three cars on there with a 16g making 350, most are making less on a 16g.
#45
Well about losing traction my evo3 hits like a mack truck and im only running 15psi. I couldnt imagine having fwd thats why i got the GSX
1995 GSX 2Gb bumper Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5 /Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs ![]() Wish list: CAMS |
