#31
Re: 2003 impala overheating problem
Napa sells a tester that will test for dissolved gas in the anti freeze a definite test for a blown head gasket. It used to be around $50.00. Most radiator shops will do this for a fee. |
#32
Thanks for the advice. Interesting enough, the radiator does not seem to develop pressure. Even after replacing radiator, water pump, new hoses, thermostat and radiator cap, still no pressure. I would think with the radiator pressure test at 15 lbs and steady, the radiator hoses are firm, that would show the gaskets are good. I do the tool borrow at Advanced Auto and get those special tools basically at no charge. ...
#33
hey guys im having a problem like that with my 2000 and 2003 impalas. neither one of them is really overheating to the point where the lights come on but on the 2000 impala it is tries to over heat when i sit somewhere (idle) but soon as it starts running again it cools back down to normal. on the 2003 impala its the opposite. temp is normal when its sitting (idle) and when i'm driving in the city but soon as i get on a highway and get to high speed it starts gettin hot but never gettin to the red and soon as i get off the highway temp comes right back down. any ideas anybody please
#35
Should start your own thread.......check cooling fan operation.....
#36
- Check you fan operations and thermostat first |
#37
the vehicle at idle running hot would be fans or the relay/power to them. sometimes the temp sensor. at idle ac on the fan should run. the other cause would be using non dexcool GM approved coolant with a universal or silicate type coolant. if non dexcool was used with DEXCOOL then check for a black goop restricting the coolant system. always use distilled water......... NOT WELL/OR CITY DRINKING WATER. these have chemicals and metals that create corrosion . use 60% dexcool for max. corrosion protection. |
#38
Having the same problem with a twist. Flushed, replaced the coolant, replaced the thermostat, replaced the radiator cap. Red light comes on when I am going down hill and cuts off when I am going up hill. I turned heat on high in the car. When going down hill air is coming out cold. When going up hill air is coming out hot.
#39
It ended up being the head gasket.
#41
I've replaced the water pump the thermostat the radiator coolant temperature switch and it still over heats and also got water on the back floor and and it's not the intake gask or the other gasket
And then the overflow bottle would be full sometimes and the radiator would be empty and it overheats everywhere I go And we flushed and bled the system Last edited by Stealthee; 03-02-2016 at 05:22 PM. |
#42
