| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Show Printable Version | Email this Page |
#31 | ||
Stay classy San Diego
![]() Join Date: May 2005
Re: New DSM, some boost leak and other problems
While an AFPR will allow the car to run a little better if he were to put a 255 HF on his car all he would get is a little rougher idle. And why would you ever not go with a 255 walboro? They are the same price as a 190, it makes no sense to rob yourself of that mod. (After looking the 255 is a whopping 10 dollars more than the 190.) People have this idea that going bigger on a fuel pump is like going bigger on injectors while that is absolutely not the case. The reason the car runs rougher with a 255 on a stock AFPR, is because the stock FPR is being overflowed by the fuel pump. IE the fuel pump is pushing more fuel than the stock FPR can handle, that is why the car has a rough idle because it's running richer than it would with a stock fuel pump or even a 190. The thing people tend to forget is that even with a 190 walboro the stock FPR is still being overflowed, the effect is simply not as pronounced as with a 255. Like the common phrase is, mod right or mod twice. If you plan on making good power on the car, there is no sense in buying a 190 only to have to switch it out for a 255 later. And the reason to go with a HP 255 over a normal 255 is that the HP 255 is able to sustain fuel pressure at high boost unlike the normal 255/190. With all that being said an AFPR will make your car run cleaner with a 255 since the fuel pressure is actually being regulated. But either way the pump is still more than functional with or without the AFPR.
1991 GSX 2.3 Stroker |
#32 | |
rewired 190 supplies enough fuel for the 16g. So I don't see why he needs a 255 at all (why bother with the shitty idle)?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
#33 | |
![]() Join Date: Jan 2007
Ok now i know the fuel mods I need. My question is, will my car drive well even if I dont get the mods right away because Im going to have to wait as couple weeks to buy them.
#34 | |||
It's really not that shitty. It's a little rough, but overall not that bad. But if he ever wanted to go larger than a 16g he would have to buy a pump. Why buy twice? Quote:
#35 | |
I have just a 255 with no aftetmarket FPR. The idle isnt too bad. I plan to buy one down the road.
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels --the DD-->99 ACURA 3.2 TL --Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods |
#36 | |||
![]() Join Date: Jan 2005
'92 3000gt SL Zoom Stage 1 Clutch Quote:
#37 | |
Hey guys, so I bought the car and ive driven it for like 5 days now. The car feels pretty good. Its going into the shop tomorrow to get the bbost leak fixed and any ohter little things. I got one question tho, when i drive the car hard and go all the way to the redline in first, then when i shift into second the car accelerates and then hits a wall at around 5000rpm. The check engine light is on so it might b that or mayb the boost leak. Also the car ill hit the wall earlier in 3rd gear and even earlier in 4th gear after the turbo has been spooling. What do u guys think this could be. Thanks alot again.
#38 | |
Fuel cut. Upgrade the fuel system.
#39 | |
So even tho im only running stock boost i need to add the fuel mods. And also do u think the boost leak can be causing this too?
