Old 04-21-2007, 02:43 PM
GeoRandy GeoRandy is offline
Re: 2002 astro vibration/shudder problem
Bravo
Old 09-23-2011, 03:01 PM
Hegedus Hegedus is offline
mine is a 99 chevy astro rwd. it only shakes when i'm stopped, but if i shift it into neutral it stops. I've already tried replacing the brakes, rotors, bearings, u joints, serviced the transm, serviced the read diff, and replaced the tss. All with no improvement. any suggestions anyone?
Old 09-24-2011, 10:44 PM
and i almost forgot i have also replaced all 4 tires, the inner and outer tie rod ends, sway bar bushings and linkages, had all the new tires balanced and aligned and still no diff in the vibration.
Old 08-12-2017, 10:15 PM
olwebley olwebley is offline
My '94 Safari has a similar problem, The vibration is worst at 110KMH. All the wheels have new rubber and have been balanced. I took the driveshaft (there was a smooth spot on the shaft that suggested a thrown weight) to a balancing shop and it did nothing to alleviate the problem. I have to think that it was not balanced at that shop. I'm considering going to a wrecker to get another driveshaft.
Does anyone know how to calculate the driveshaft's rpm at any given road speed?
Old 08-12-2017, 10:16 PM
This is a reply to Hegedus: Maybe motor mount(s)?
