Old 10-17-2006, 02:44 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: i did it i orderd my front clip
Originally Posted by StealthModifier
also pull off the oil pan to check if any of the rods are loose. i hope everything checks out alright for ya.
ya, while you're down there, might as well inspect the bearings!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-18-2006, 12:41 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Ok finaly got it off the trailer today! what a pain in the ass.. it took 6 mexicans 3 horses and 2 scooters to get that damn thing off.. any ways thanks for the ideas bolth are good and i will check them out... never actualy done a compression test.. what should our cars be at? and do i just screw it in the spark plug hole and crank it over and see what it reeds?
Old 10-18-2006, 12:00 PM
Igovert500's Avatar
blue + red light magnet
compression test
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-19-2006, 01:02 PM
jason_bet's Avatar
Thanks for the refresher on compression testing.. i have about 110 in the front 3 cylenders i will have to take the intake manifold off when i get off work.. its just my lunch right now.. any ways that makes me excited.. oh and the RHD.. HOLLY SHIT! there is so much crap i would have to do.. i need to post pictures and i have lots of questions.. and concerns about it.. maybe i can get some advice.. i will have to cut and weld some stuff. and with this unabody.. it makes me nervis.. so yeah.. i will post latter tonight about it.. Thanks guys
Jason
Old 10-19-2006, 10:22 PM
StealthModifier StealthModifier is offline
Old 10-22-2006, 10:41 PM
jason_bet's Avatar
Today I pulled the motor and tranny out of the clip.. It came with no real problems.. just kinda a pain getting that rear motor mount. I am doing the RHD conversion.. i can see a lot of problems comming my way.. but it will be worth it.. I will post a some pictures as soon as i can find my camera.. There are some big differences in the usdm and jdm models.. I need to order the window switches for the doors cause they will be swapped.. and i need the active aero and cruse control switch panal.. and last thing i will need i think is the botom of the shift boot the plactic part that clips into the floor panel.. any one know where i can order these parts? from NZ or japan.. or wherever? Also i have herd about some exhaust systems that have the option to open and close the downpipe? I have not found any info on this though i looked all over stealth316.com but didnt see anything making me dout.. There is a switch on my clip that has the option of normal or silent?
Old 10-23-2006, 12:57 AM
Linebckr49's Avatar
its called "active exhaust" and its a standard feature on your 92 VR4. simply routes the exhaust gases through one of the two tail pipes, or through both.
93 3000GT base
Old 10-29-2006, 10:21 PM
jason_bet's Avatar
I Finaly found my camera!! It's dark outside so its kinda hard to see but this is my car in the garage with about every thing out of it
a little bit closer here i got the fire wall.. as you can see i already removed the AC, heater core, accelerator cable, steering column and the engine wire harness
The view from the inside.. just the wire harness left and the suport beam..
The motor on a the host
Old 10-29-2006, 10:26 PM
jason_bet's Avatar
Ok i got some more.. i used some MSD wires and some denso iridium plugs..
here is my bag of candy that got me threw the day...
My RHD dash and my downpipe hollow cat.. and some mufflers
The clip is outside so its kinda hard to see
Old 10-29-2006, 10:29 PM
jason_bet's Avatar
more pictures of the clip
I wanted to get some before i pulled the motor and dash but i couldn't find my camera
the guages are different then my stock ones..
and this is all the stuff from my car
Old 10-29-2006, 10:41 PM
Linebckr49's Avatar
nice pics!
question: how did the front clip arrive at your workplace? was it wrapped somehow to protect the interior & dash from the elements? i assume it was on a crate? just curious.
you've got quite a few extra parts you can sell to make some of your money back. allow me to be the first to contribute. i remember there's a new guy here to the 3/S forums on AF and he was looking for a passenger turn signal for his 92 SL.
also, could i have the driver side foglight (LHD, that is, so looking at the car from the front, its the one to your right) ? $40 shipped?
you can also sell those headlights, snake eye lenses, bumper, fenders, hood, some of the fluid reservoirs and various miscellaneous lines in the engine bay. oh, a friend of mine needs a front wiper motor. how much do you want for it?
didn't mean to turn this thread into a "part ur car out" thread. perhaps you could start another thread for those transactions...if you like. just trying to help you out. keep the pics rolling!
93 3000GT base
Old 10-29-2006, 10:58 PM
jason_bet's Avatar
[quote=Linebckr49]nice pics!
question: how did the front clip arrive at your workplace? was it wrapped somehow to protect the interior & dash from the elements? i assume it was on a crate? just curious.QUOTE]
Yeah it was shipped on a rather large pallet.. it was a odd shaped one... and hard to get off the truck.. it had a lot of plastic rap around it to protect every thing.. and there where some added parts he through in there under the dash and under the shrink rap.. like the srs air bad box and some other little clips.. I still need the bottom of the shift boot for the RHD cars.. and the window switch's for each of the doors cause there swaped.. i also need the cruse control/active aero switch panal.. oh oh and the ebreak asembly.. but I think that I have every thing else that i need.. The only other weird thing is that i have not found the side mirrors ajustment panal.. the jdm one is not in the same place as the usdm one.. so not sure what i plan to do about that yet.. anyways i will get some better pictures as i put this back togeather... Yeah i will sell a bunch of stuff after i am done.. i just want to make sure every thing works before i sell off everything.. but i will save that fog for you asuming my works fine still
Old 10-30-2006, 12:22 AM
AutostradaVR4 AutostradaVR4 is offline
damn man. looks like one hell of a project! never realized that the JDM center gauges were different from ours...and what kind of mufflers and DP are those if you dont mind me asking?
anyways, good luck with the build!
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 10-30-2006, 03:07 PM
Igovert500's Avatar
www.stealth3000gtsalvage.com
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-31-2006, 08:58 PM
jason_bet's Avatar
There just ebay mufflers and downpipe.. nothing nice or anything.. thats a cool web page but I dont think there going to have the things for the RHD.. i have all mine still and there in good shape its just that they are different on the RHD.. anyways i will post some more pictures later i already started drilling out spot welds!!
