| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#31
Re: V8 Rumble
![]() 1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
#32
Re: V8 Rumble
Bob means an inline 4, where the two end rod pins are up at the same time, the two center pins should be down.
#33
Re: V8 Rumble
Seatbelts Saved My Life
#34
Re: V8 Rumble
bikes?
AF's Guidelines Read them. __________________ ![]() Currently in the process of re-hosting my photos. If any go missing, drop me a PM. |
#35
Re: V8 Rumble
Some boat motors are V4, it saves space
#36
Re: V8 Rumble
no, I'm talking about "big bang" motors. Its something you only see in very serious race applications.
A I4, for example, 1 and 4 are at TDC at the same time. Normally you would have them fire 180 out of phase to spread out the power pulses and reduce vibration. On a "big bang" engine, 1 and 4 are fired at the same time, as are 2 and 3, so instead of 4 power pulses per 720 degree's of crank rotation, there are only 2. The reason they do this is to increase traction. The less power pulses, the more time the tire(s) have time to recover from power pulses causing traction loss. Pretty much all the GP bikes use this method these days. Some are even playing with a combination of big bang and traditional firing order. For example firing 1 and 4 at the same time, but keeping 2 and 3 offset. The reason for that was to improve engine longevity....they were breaking stuff too often with the big bang engine and losing races. It doesn't reduce your power in any way, just delivers it differently to the tires. btw, it completely changes the sound of the engine. since its halving the number of power pulses, it makes it kinda sound like an engine with half the cylinders....but not quite. Very unique sound Anyway, thats why a "big bang" V8 would sound kinda like a really big V4, and it would apply power like a V4
life begins at 10psi of boost Three turbo'd motorcycles and counting.
#37
Re: V8 Rumble
I need the lope like I need more cowbell. Big bang engines sound cool though. Thanks everyone for thoroughly explaining that it's the firing order, the number of cylinders and the displacement of an engine that attributes to the sound.
#38
Re: V8 Rumble
The ignition is worked out how? twin tower coils? |
#39
Re: V8 Rumble
wouldn't it just be differerent positioning of the contacts inside the distributor?
#40
Re: V8 Rumble
Attempting to make that work with a distributor, however, I think would be a lost cause. If you're going to spend all that money making such a unique motor, step up and buy a real ignition system
#41
Re: V8 Rumble
#42
Re: V8 Rumble
correct, DIS stands for distributorless ignition system. Which is a very bad name for coil packs, one coil per 2 cylinders.
COP (coil over plug) is the reference name when its one coil per cylinder.
