#31
Re: 98 GTP losing fuel pressure
I ordered a FPR and it will be in the store Mon PM so I will stick that in there say a blessing/prayer the give er a turn. Will either post my joy or sorrow afterward.
#32
I replaced the FPR and still the same old same old I do not think I have injector stuck open as when I turn the key off my fuel pressure does not bleed down and if there were an injector open I would think this would cause the pressure to bleed off once the key was turned off. I have even went as far as swaping the original fuel pump back in o see if maybe I had a bum pump but both pumps do the same thing. and as I stated before I believe my original problem was mainly with the crankshaft position sensor. ANY NEW IDEAS or do I buy some lube and take her to the dealer
#34
#35
The fuel pressure declines steadily from startup of 44psi and at about 10 psi the car will die. this is in amatter of about 3-5 seconds. As I mentioned though if I pump the accelerator the pressure will increase to between 40-60 psi depending on how hard I hit the gas.
#36
#37
did you do the bend pin 85 trick to see if u can bypass the fuel pump resistor?
goto here for a pic http://www.scacgp.com/mods/fuel_fix/relays.jpg |
#38
http://rmcgp.clubgp.com/fpresistor.html It worked for the other guy that posted here and had the same problem. One down, one to go.
#39
he could try this one, just bend the pin, no need to add another wire on there
#40
now Im confused. both diagrams show jumping a different relay. I did not try bending the pin on relay #15 which is the fuel pump speed relay. I did bypass the #14 relay by jumping a wire from #30-#87. Do I need to try again???
#41
Try it again to rule out human error. BTW - Remember either fix is just a temporary remedy. The fix is to get a new fuel pump resistor. It is not a good idea to run the fuel pump in high speed all the time. The low speed circuit has a purpose to allow excess fuel that is not needed back into the return system back to the fuel tank.
#42
wouldnt hurt to try it. why not?
#43
I did take out the headlight already but I did not see any thing other than lighting wires. I will have to look again I even put it up on the lift and looked from the bottom still did not see it. is it behind the washer fluid bottle? |
#44
I tried bending the pin #85 over and the car actually ran for a minute. I will pick up a new resistor tommorrow and put it in. I cant believe I botched that bypass. When I did that I ran a jumper wire from #30 to #87 on relay #14.
Is a resistor from autozone sufficent or is this one of those that needs to be a high quality item? |
#45
Resistor is by the washer bottle. Why did it only run for a minute? Or did you turn it off?
