| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
#31
Re: I think my ISC ( IAC ) busted,
one quick question , how many O-ring is support on the biss crew ?
GM FOR LIFE !! NEW 1997 Camaro z28 6 speed illa never going back to import , but killa alway be nice to any DSM he saw ![]() looking for 2002 Trans Am LSX UPGRATE 2010 !! 97 Camaro Z28 95 camaro lt1 1992 Pontiac Firebird v6 auto -sold - Pony 1998 Mustang GT 4.6L Manual. Black 1995 Eagle Talon TSI AWD Turbo manual R.I.P 1994 Mitsubishi Eclipse Manual gray -Sold 1997 Mitsubishi Eclipse RS Auto White - Sold |
#32
just one at the top of the screw.
_________________________________ Nathan Car: used to be a 91 N/T Auto now a 91 Turbo 5 speed stock Tsi setup except n/t 9:1 internals 9 psi low/ 12 psi high |
#33
no the 420a's dont have fiav. i cleaned the TB on my rs tons of times and never had any problems.
-MODS-Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/ 1/4 mile=14.3@103MPH |
#34
#35
'92 3000gt SL Zoom Stage 1 Clutch Quote:
#36
i dont have my rs anymore or i'd go look, but i'm guessing it's for the idle, since 420a's dont have biss.
#37
You guy feel me now ? I fix my Idle problem , Yesterday I was doing fuel fitler change, and I cant get the bottom bolt off, I think I strip that shit, so today I went to car care clinic ( I dont know you guy knew this shop or not ), after 1 hours waiting, they cant get the bottom bolt off either, I dint tell them that I try before and it not work, they told me go down town ( 30min away ), when I get to down town, traffic like shit, and my car idle at 4k , I was really piss off, I have to stop by the gas station and pop the hood, let it cool down, then the idle drop down to 3k, so I keep on going, After the third time stop at the gas station, the fourth time I was really really piss off, I get tool box out and uncrew 2 bolt of that hold the TB cable, when I loose the second bolt, it adjust by it self, and my engine is quiet, I was like " WTF ), I went inside and check the rpm it was 1k, I was really happy " shit I fix it ", I adjust the biss ( it was all the way in before ), I back 2 full turn, and my idle at 2k, I adjust a little until it around 900-1.1k, I was happy, really happy, ( long time ago my 94 eclipse, I fix the idle just by adjust the TB cable ). I read all the Idle problem threat, and non told me to adjust the TB cable, but now it fix, I can idle my car after hard running now, thanks all you guy for the help, " Kevin I preciate " Im gonna run for couple day, let see my idle change or not, I keep this threat update.
#38
That's all your problem was? A simple throttle cable that was too tight? God I wish my problems were that easy to fix.
#39
Walmart - pop hood, go shopping, close hood, and go home Go GF house _ pop hood, go inside, take her out, close hood, and go eat. and... almost most every where I went, I alway pop my hood, and let it cool down. suck, I think my hood cable is loose, any one know how to tight that cable again ?.
#40
I think we just hit the record for smileys in one post.
#41
#42
I'm pretty sure I always recomend adjusting the cable before adjusting anything else. I'll guarantee you there are a couple posts where I suggest this on this forum alone
At any rate, glad it's fixed!
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
#43
Well I think my TB cable is dry up, some time it stuck at 2k, I have to push in clutch and rev high, then it go back down to normal, what kind of lubicate do you guy recomment for TB cable. BTW any body here ever need a ISC, I have one that work perfect ( bought of ebay ). I dont need it , you guy already knew why
#44
I've had a rusty TB return spring cause me nothing but pain and misery with idle speed for months. A little WD40 took care of it. Ultimately some white lithium grease or similar would be better (last longer). I would start with that. I've never heard of the cable itself getting sticky, and if it did I would just replace it. Not worth assing around with it, when you can't get to the middle of the cable inside the jacket.
#45
