| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#31 | ||
![]() Join Date: Jan 2005
Re: Dropped Nut Into Intake!!!!!!!
Sooooo........ They stopped making/selling the old system as a whole...but instead continue to sell the individual injectors for it. So if you have a single bad injector on the original system, you can replace it for about $100. What's so odd though...is that you can order this NEW IMPROVED spider assembly as a whole, for under $300 with the regulator included. I told the dealer they should make a note of that......because until I gave them (and other dealers) the exact part number for the new spider assembly, they had no full assembly available for my vehicle....only single injectors. Don't know if its an intentional mistake by GM to rape customers at $100 per injector, or if its just a screw up in the way their listing is. Thanks to Blazee for the info! Here's the part numbers: 12568332 - MFI Assembly 88894355 - Bracket 17113215 - Seal kit But, the bottom line is, I bought the new fuel spider. The gasket kit, I'd already purchased when I was trouble shooting...it includes the gasket for the throttle body, the gasket for the upper intake cover, and the gasket for the fuel spider where it seals inside the cover (seen in orange below). The bracket IS different from the original, and although it appeared to be similar enough to use the original, its not. The NEW injector lines are thicker then the originals, and the bracket needs more clearance for them all to fit in. Once all the injectors are inserted, they put slight pressure on the fuel spider in the direction of the firewall...which keeps the bracket seated firmly. ![]() Cross your fingers that this takes care of my horrible MPG...unless my gauge is wrong, my pressure is still only 54psi after the new fuel pump, fuel filter, fuel line o-rings, and new spider assembly/regulator. Go figure~!
doing a job? take digital pictures before and after! helps you for reinstallation, and everyone else who will do the job later! |
#32 | |
Maybe nobody understood what I have said. the nut went through the hole where you fill the engine with engine oil. thanks in advance...
#33 | ||
Oh, and where you posted. This thread is 7yrs old.
Post back, that's what makes Forums Work. |
