#31
Re: how many miles does your chevy have?
lol 2 and a qtr, doing the lifters wouldnt be bad, hell if your lucky the just need adjustment
#32
footballmoose, whatever you do Keep That S10!
It's more reliable than Old FaithFull |
#33
1992 s10 Blazer, 4.3L, 4X4
Bought in 2001 from sister. Little over 167,000 miles. 268,760.45 km for you Canadians. |
#34
I had a 1992 Silverado with 299,000 miles and I sold it for 2,500 dollars... pretty impressive truck.
#35
Hi, My 1991 S10 2.8fi Has 289000. Only A Waterpump.fuel Pump At 225000 Original Clutch Still In It.
#36
I have a 1983 Chevy S-10 4X4 with a 2.8 that has 323, 467 miles i bought it from a contractor.
#37
226,228 it pretty good still but still burns a littel oil!!!
#38
Odometer reads 23,427 and the contractor i bought truck from said its all ready rolled over three times. So i am going on what he is saying. The engine runs pretty good it uses about 1 quart of oil between changes.
#39
1983 S10 Blazer 4wd Tahoe = about 150,000 miles I think, had to change the speedo yrs ago.
Bought in 2000. Before that was tranny rebuild and engine rebuild. I've since replaced the rear end, tranny mounts, gas tank and pickup, gas line, brake lines, oil pump, gas pump, brakes master cylinder, engine mounts, alternator, starter motor, cab fan blower motor, vacuum connector atop transfer case, battery, full exhaust system and convertor, shoes and pads ofcourse. Everything works great. Starts fine even in -30c. I found it definitely prefers full synthetic 5w30 oil. This is because it stopped burning oil and the level stopped dropping. Someone here long ago mentioned it had to do with fresh esters from the synthetic, helping the valve guide and piston seals.
1983 S10 4WD carbed 2.8L automatic w A/C |
#40
87 s-10 2.5L 4-speed standard cab 185,645 miles on it..sat for almost 5 years b4 i bought it and it cranked right up after putting a new transmission in it...no rust spots except in the bed
#41
I've put one alternator on mine, replaced heater hose, radiator hose, radiator, 1 water pump. 2 sets of front brakes, 2 heater & air condition blowers, 2 air conditions pumps, 3 batteries, 4 sets of tires, 2 fuel pumps, fuel injectors, Did about $150.00 front end work at about 137,000 to 140,000 miles, front end has been lined up 2 times, 1 EGR valve. Replaced the ABS brakes box that is under the hood with one from a junkyard, 2 months later it did the same thing as my old one, I forget the name for that thing but they cost about $1,500.00, the top bleed plunger on the back side would not stay in, I put a metal band over it where it would not come out when I hit my brakes and let the brake pedal go to the floor.
At present time I've got a lifter that sticks after it sets over night, after starting it us and it get warmed up a bit, it loosens and runs just great. I've changed my oil and used a quart of Rislone, I'll see how this turns out. All in all its been a great ride, never had to add a drop of oil, just regular oil changes & such. I feel my problems have been few, we bought a Jeep Cherokee Laredo new in 02, now both the wife and I wish we had bought another new S-10 Blazer.
Have a great day, Jerry 1992 Chevy S-10 Blazer 4 X 4, 4.3 W engine 3.42 gears 172,000 & still going Sold 2010 Toyota Tacoma Double Cab 4X4 V6 4.0 V6 DOHC 24V VVT-i 236HP Engine 12,000 plus miles Bought 10-22-11-2001 Toyota Camry LE SuperWhite 4 Door sedan I-4 89,680 miles |
#42
194,000
95 / 2.2 / 5 speed Drove it from Kentucky to South Carolina In June no problems. Had to bypass my heatercore as it is broke. Bought it lowered and Raised it back up Tail pipe broke off (when it was lowered) Broke frame (when it was lowered) Replaced Universal Joint Replaced Tires Oil Getting ready to replace plugs/Distributor Cap/ Wires and Flush radiator when I replace Heatercore I live in a area with rough roads. |
#43
That lowering it sure must be hard on the hard frame.
#44
my 90 cav 2.2 has 98004 mi
and my 94 blazer 4.3 has 133k, last my 2007 dodge caravan 3.3L 61025mi my old and dead 87 custom deluxe had247,000 (R.I.P.) |
#45
I have a 97S-10 4cylinder that is just over 187,ooo miles. I would not believe my eyes but I keep looking to see blue smoke and there is none. Change the oil every 5k. Cross my fingers.
