#31
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Its Alive!!!!
i have also been told to replace all because one going bad is a sign that all are getting week or what ever i don't know for sure if you should but it would save you time in the long run if another one fails in the future |
#32
Re: Lumina Dies randomly... weird problem
if you have 3 wires on your oil sending unit short out the 2 across from each other. at the plug with a paper clip. fuel pump won't come on if the oil pressure is low.
#33
Update
Problem was fixed.
Cause: Fuel Pressure Regulator Pulled the vacuum hose off the FPR during idle, and massive amount of fuel squirted out of the valve, indicating a torn diaphram which is keeping the fuel pressure from being lower during idle (which explains why the car idled badly and fouled plugs, but ran normally at WOT). Cost me $70 at AutoZone, and took 30min to replace.Future Note: Check the FPR by pulling the vacuum, to check for any fuel leaks. Fuel should NOT make it's way out to the vacuum, nor should you smell any unburned fuel from the line. Any signs of fuel in the vacuum is an indication of a FPR going bad, which will throw all the "Missfire codes", which is NOT caused by bad coils, wires, or plugs, but by the combustion chamber flooding itself.
AudiGeeks.com: Where Knowledge = Horsepower |
#34
Re: Update
good diagnossis but don't say that the coils can't cause a miss fire code a combination or problems can cause one code or one problem u don't even think could cause the problem the computer isn't smart it only knows if some thing is wrong so if its miss firing it will only know its missing and not exactly way it is i didn't have any codes telling me my injectors were bad i didn't even have a miss fire code but eventually i got a o2 sensor code after running it with the super rich mix one or more of my injectors was stuck open i din't have any fuel in vac line to regulator and ohm test found a few bad injectors |
#35
Re: Re: Update
Of course we cant say it's always NOT the coils. Unfortunately these cars have a pretty prehistoric diagnostic system, in which one must use reason and proper judgement to diagnose and fix the problem. In my case, the injectors were trimming properly, and I believe the on-time was intact, only with full WOT fuel pressure which was flooding it out. Only codes I had were "Random Missfires" and "Missfire Cyl #6". For future reference, before the guy goes out and spends ~$200+ in new coils, wires, and plugs and pulling their hair out like I did, the FPR is a fairly easy check. Thanks again for all the help guys.
#36
Re: Re: Re: Update
well it is very important to check everything before buying parts cars are not like they use to be all thought they are not as complicaced as some people make them out to be they are deffinately not as easy to trouble shoot with out access to some special tools and equpment they are all most impossible to find the exact problem |
#37
Re: Re: Re: Re: Update
#38
1963 Triumph TR3 12K 1995 Buick Century Special 178K 1999 Chevy Lumina LTZ 160K 2001 Suburu Forester 53K 2002 Oldsmobile Aurora 3.5 45K 2004 BMW Z8 3K 2005 Dodge Charger .5K 2006 Jaguar XJ12 1K
#39
Re: Re: Lumina Dies randomly... weird problem
i know this is the lumina forum and not pontiac grand am forum but has any body had problems with the trans in those cars slipping in 1 and 2 but being ok in d the car is my sisters i don't drive it but she told my dad who told me and he thinks its the tranny on its way out and i didn't know if a trans fluid change and filter change would help or if the tranny is shot he says the fluid looks ok the engine is the 2.5 four cylinder tranny is an automatic 3spd don't know if its th125 the car has about 140000 miles and never had the fluid changed so i was hoping that would help because i don't want to take out the transaxle but i guess if i have to i will |
