#31
Re: Passlock System
If the battery is dead or has gone dead. Put a new battery in it first. Then if no start or security ligt is on. Turn key on for 10-20-30 minutes and see if it will over ride and start. Also pull codes and see what is going on. And post back any codes no. Let us know how it goes. MT
#32
Re: Passlock System
Here is a re-write of the GM upfitter bulletins ( http://www.gmupfitter.com/publicat/bull/bull2wsA.pdf and http://www.gmupfitter.com/publicat/bull/bull26.pdf ) so that we can more readily apply it to our cars! There is no need to add a remote starter.
PASSLOCK I or II DISABLEMENT The following is a procedure to disable Passlock I or II Systems for vehicles in which remote start/stop system installations are required. This procedure is required because a remote start system will not function with the current Theft Deterrent System (Passlock) which is included on many 1996 and up GM vehicles. Please note that this modification is intended to be used only in conjunction with the installation of a remote start/stop system and does not provide a procedure to install a remote start/stop system. CAUSE If an attempt is made to start a vehicle by a means other than a key rotation in the ignition switch, the Body Control Module (BCM) will interpret this start as a vehicle theft and disable the fuel injectors. CORRECTION A minor wiring modification may be made to allow the vehicle to be started remotely. This modification includes adding a switch to allow the customer to select “ON” to disable Passlock or “OFF” for normal Passlock operation. CAUTION: When this modification is performed and the switch is set to the ON position, the theft deterrent feature will be disabled. When the theft deterrent is disabled the SECURITY or THEFT telltale will light up indicating that the theft deterrent system is NOT functioning. PASSLOCK MODIFICATION Refer to appropriate GM service manuals and/or SVMQP Electrical Guideline Manual for instruction on splicing and electrical connections. 1. Select a suitable on-off switch (see note below) which will be used to disable/ enable the Passlock System. Mount the switch in a location such that it is accessible to the driver and will not interfere with normal vehicle operation. NOTE: This is an extremely low current circuit (approx. 7mA), it is therefore very important that a high quality, low energy, fast acting switch be utilized for this application. 2. Turn the ignition switch to the OFF position. 3. Locate the Main Ignition Switch Harness. GM's Passlock System wires exit the Ignition Switch Tumbler together and then join with the Main Ignition Switch Harness. (See http://www.bulldogsecurity.com/ or http://64.85.6.118/diagrams/diagrams.asp and select your Make, Model and Year for wire colors and clues on the quickest way to access these wires.) 4. Locate the Yellow Passlock Data Wire which is included in a bundle of three tiny (20 GA) wires wrapped in friction tape. Cut this wire and splice a 0.5mm2 (20 GA) yellow wire to each end of the cut wire. Keep wire length to a minimum. Route modification wires clear of moving parts. Connect the yellow wires to the switch such that the contacts are OPEN when the switch is in the ON position. 5. Turn modification switch to the OFF postion (contacts closed). 6. Start vehicle to verify normal operation. If engine “cranks but will not start" recheck the switch position (contacts should be closed), wire connectors and modification wiring. SWITCH OPERATION To enable remote start: Start the engine with the ignition key (modification switch must be in the OFF position). Turn modification switch to the ON position (contacts open). The SECURITY or THEFT telltale will light up indicating that the Passlock System is inoperative. Once the SECURITY or THEFT telltale has been on for at least 5 seconds the vehicle can be turned off and then remotely started. To disable remote start: The Passlock System can be reactivated by turning the modification switch OFF (contacts closed). Vehicle can either be running or off when this is done. Please note that the VCM/PCM will record Diagnostic Trouble Codes (DTCs) related to the security system when the modification switch is in the ON position (circuit open). This is due to the way that the VCM/PCM interprets this condition. NOTICE Any condition which removes battery power from the Vehicle Control Module/Powertrain Control Module (VCM/PCM) (e.g. dead battery, disconnected harness connectors, etc.) will prevent the vehicle from being restarted. If the engine exhibits a “cranks but will not start” symptom, place the modification switch in the OFF (contacts closed) position. This will reactivate the Passlock System and allow the vehicle to be started with the ignition key. Ray Proud Member of The Anti-Passlock Club
#33
I have a used 99 Astro Van purchase 3 years ago from a dealer without a pass key. The van will start and run but I always noticed the "Security" light come on. My problem is that if I turn the vehicle off it will not re-start until the passing of time. (I guess the 10-minutes I read so but about).
The yellow data wire trick did not work. I cut it will with the motor running and the light came on but would do re-start until I connected the wire and waited. Then it would. It seems I will have to have the BCM replaced with new passkey and then disable the "feature". I would hate to trade it off to some other fellow as it has taken me 2 years to come across your thread with the obbious problem. Any other ideas? |
#34
Re: Passlock System
Looks like the 1st one did post....more details
Thanks to this thread a 2 year old '99 Astro Van mystery is solved. I noticed the "Security" light on sometimes but the van always started. My problem is I never received the "Pass Key" when I purchased the vehicle used from a dealer, just hardware store type keys. The vehicle starts everyday unless I turn the vehicle off and try to re-start right away. It seems to be more of a problem the last year. I tried the yellow data wire cut with the engine running and the security light off. The light came on as described but the van would not start. I reconnected the wire and let the 10 minutes pass and it started. I tried disconnectong and re-connecting as described but the light never goes off once it is on. I guess I need to purchase a new system complete with pass key and then apply the fix. Any other ideas |
#35
Re: Passlock System
Guys, Passkey 1 and 2 systems can use regular keys. The Passkey 3 or 3+ systems can't. Inside the ignition on PK1,2 systems there are tiny magnets that operate the security system. Most of the time those wear out or move to where they won't activate the needed resitance for the BCM to read. The only way to fix that is to install a new decoder/ignition module or to use resistors in between the yellow and black or orange/black wires.
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
#36
Re: Passlock System
how u doin guys, i have a 1998 v6 malibu 115,000 miles. I had the Theft System problem where you have to wait 10 minutes to start, it lasted about a week. Now the car wont start, well it stays on for a second and shuts off but this time the Theft System light does not come on. Do you guys think if i did the toggle switch solution it would work? thanks for the help
#37
Re: Passlock System
yes it could but you need to diagnose what's actually at fault.
#38
Re: Passlock System
I’ve been reading up on how to disable the Passkey II alarm system (by cutting the yellow wire [data wire for Passlock system] and installing a toggle switch) but the information was for a Malibu and Oldsmobile. Does anyone know the wire color and its location for a 98 Buick Regal 3.8l. My car is like a reoccurring bad nightmare. It seems like every three weeks now the car just cut off on me while I’m driving, thank God for Triple A. Took it to the dealer, and low and behold they said the computer read code # 1626 (ignition cylinder) and suggested that I replace it for a cost of $545. The other 3 times that the car cut off on me, I had it towed to my mechanic who got the car started without replacing the ignition cylinder. This causes me to believe that the problem is the alarm system. Can anyone help
#39
Re: Passlock System
Ray |
#40
Re: Passlock System
http://64.85.6.118/diagrams/diagrams.asp Here is a specific "how to" for VATS bypass. http://vats.likeabigdog.com/ This new product is great and easy, but pricey if you have to buy the whole set. Maybe call the number listed to see if you can buy the specific one that you need. http://cgi.ebay.com/ebaymotors/LOCKS...QQcmdZViewItem Ray |
#41
Re: Passlock System
You may have code #1626 but your car shutting off while driving isn't a symptom of it. Once your car successfully starts, VATS or Passlock can't shut it back down. You have something else going on as well.
#42
Re: Passlock System
Anyone know if this method works on an '05 Malibu LS?
#43
Re: Passlock System
2005 Malibu Maxx-- Passkey 3 Transponder-- No Just remember, this can void your warranty! Ray |
#44
Re: Passlock System
Well, I really don't know what is going on with that car. The car just stopped running again. The dealer said that it is the ignition control module and that it would cost $454. When the car cut off the other three previous times I 'm almost certain that my mechanic replaced the ignition control module (twice) and told me to take it to the dealer ther next time the car cut off because he don't know how to correct what is really wrong with the car. Can anyone offer any insight?
#45
Re: Passlock System
Sorry, without having the car in my hands at the time it does it, I can't say what could the problem be. I had an older Caddy that would shut down if you went a constant 40-50 mph. Above or below that it would be fine. Ended up being a rotted battery cable.
When it comes to electronics, it can be a number of things being the culprit.
