Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 12-29-2011, 06:04 PM
tmctague tmctague is offline
Re: Aveo factory radio unlock code- DEALERS CAN'T HELP ME!
I had the same problem. We installed a different radio, but that one does not work either! The code is on the radio itself, right? Why wouldn't an after market stereo work?
We ended up blowing a fuse, couldn't get it out of park, and had to take the car to get serviced. Not happy with Chevy on this one...
Old 12-30-2011, 11:19 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
I see that you took your vehicle in to get it serviced - was everything successfully resolved?
Sarah
GM Customer Service
Old 12-30-2011, 11:34 AM
Sarah
GM Customer Service
Wow, I did not expect someone from GM to answer my request. Thank you. My mechanic repaired the issue to get the car out of park by replacing a fuse. However he could not get the aftermarket radio to work.
Also, the recalled seatbelts on the 2004 Aveo have failed again. We have to replace all of them, as well as the seatbelts on our Suburban. On both, the mechanism sticks, and you cannot pull the seatbelt forward. What is the lifetime of seatbelts?
Thanks again for your reply, I'm impressed that you monitor this forum.
Old 12-30-2011, 12:59 PM
I would be happy to look further into your seatbelt inquiry. Initially, my investigation into the resources I have available didn't show much, but I would be able to learn much more with the last 8 digits of your VIN, which you can send to me in a private message.
All the best,
Sarah
GM Customer Service
Old 02-06-2012, 12:41 PM
emasaurus emasaurus is offline
DON'T WASTE YOUR TIME TYPING IN RANDOM NUMBERS!!!!!! My battery died and I had to do a whole lot of searching the web to find out an easier way than typing in random numbers!
There should be a plastic card similar to a credit card with your owners manual packet. It will have a 4 digit code number on it. There is a slot at dash level in the driver's side door. turn the ignition to the position where your dash lights come on and turn on the radio. Insert the card into the slot and, using the numbers on the radio, punch in the card code number. (I don't understand the whole, putting the card in the slot, just typing in your number listed on there works just fine) Radio should come back to life. If no card can be found, contact a Chevy dealer fo a replacement card.
This card saved me hours of trying to figure out what number I had to use to unlock my radio!
Old 02-06-2012, 01:09 PM
ricebike ricebike is offline
emasaurus, if you read the past postings from used car owners...
they don't have that owner's manual packet with the plastic credit card ~
thus they need to find other ways of getting the code without getting RAPED from the stealership
viva la internet!
from what i'm getting from other members here, they are being charged for it... if they find their code, then they can supply their own marker & write it in the glovebox!
Old 07-10-2012, 07:18 PM
chevypetpeeves chevypetpeeves is offline
Hello all you Chevy Aveo owners that are so frustrated with the radio code such as I am. As with some of you I bought mine used and it did not come with an owners manual or a radio code. (never seen this before in my life, weird!!) Anyway, left the lights on one day, the battery went dead and then I had no radio for some time, just this annoying word flashing on the radio "CODE _ _ _ _" Holy Crap!!! Moving on, I asked my wife to start looking on the net for some answers, she came across this blog within 5 minutes, printed out the list that a couple of members posted, went to the car and the 5th code she tried worked!! Horray!!! I would like to personally thank everyone who spent time into getting these codes and sharing them with the rest of us.
Don't pay a dealer to do this. One of these codes will probably work, it's like programming a universal remote really. The garages are just looking to make an extra buck from us poor car owners. We pay for enough, thanks to the smarts of some people out there we are able to figure some of the small things out for ourselves.
Thanks again everyone, you have saved someone alot of grief
Old 07-10-2012, 10:18 PM
danielsatur danielsatur is offline
It's probably best to get a new JVC FM stereo with a USB conn for a thumb drive, Aux port for Ipod/IPad, and audio Blue Tooth for Google voice, Maps, Hulu plus, pandora. and WWW.
Caution-
A 12VDC memory saver tool is used to save codes during a battery replacement.
Old 10-27-2015, 05:57 AM
ihabaly ihabaly is offline
I have the same problem and went to my dealer. I got a code 3681, however the keyboard only have numbers from 1 to 6. Any clue?
Old 10-27-2015, 09:34 PM
Tech II Tech II is offline
Key on, radio on....
You press the hour button, until the first two digits appear..."36"...
Then you press the minute button until "81" appears....
Then you press the AM/FM button and "SEC" will appear...
Turn ignition off for 5 seconds....then turn ignition to on and turn on radio...
Old 04-11-2016, 05:26 AM
bgmilew bgmilew is offline
Hallo, you can check for codes and bins over here: http://service-diagrams.com/
Old 08-14-2024, 01:59 PM
Pookee Pookee is offline
Just wanted to say Thank You !!
I have a 2004 Aveo and the 10th code (2145) unlocked my radio.
