Old 08-24-2005, 09:09 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
Re: front end clunk when backing up?
watch your voltage and see if it drops a little. i know drivng my truck that even cruseing i can see might lights flicker when the bass hits.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 08-27-2005, 05:35 PM
i tired to pull the upper bushings today with no luck. i did how ever got the rubber out of one and it was fine. just around the very edges that stick out where the bolt head and nut is a little cracked. i couldn't see any place it wore though. i was looking at my brakes and it looks like theres a place on the calipair that looks like the pad might be hitting. could this cause it?
Old 08-29-2005, 04:11 PM
a77wing a77wing is offline
i have finally solved the clunk!!! turned out that rlith was correct. it was the upper control arm bushings. $8.99 at auto zone. not the easiest to replace, but a little heat and a big vice&hammer got the job done. thanks to all who contributed. if anyone has any questions about symptoms or fixes that i had tried, fire away! thanks again everyone, she's like new again!
Old 08-29-2005, 04:56 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Not that anyone pays attention to me..
Old 08-29-2005, 05:58 PM
replaced them as well but still clunks.
Old 08-29-2005, 06:00 PM
rlith's Avatar
Re: Re: front end clunk when backing up?
both sets of uppers? have you checked your ball joints? Have you checked your hub bearing?
Old 08-29-2005, 07:29 PM
replaced both sides. how do i check the hubs. upper ball joints might have 500 miles on them and the lowers are about 2,000 maybe? i did see a place on the control arm that was hitting. i'm going to put some rubber there and see if it goes away.
