Old 07-23-2005, 12:43 PM
mickbench's Avatar
mickbench mickbench is offline
Thank you everyone for your great comments.
As for the ride height, it was built OOB. I could have brought some new rims etc, such as 19" or something, but I wanted it to be just as you would buy one from the Honda dealer. The only change I did make, was the roof. There was no way it was being painted the same as the body.. It just had to be black.
The kit is a great kit, but the lights are complicated, and require a lot of time and work. I "only" just got away with my lights, so anyone looking to build this kit, beware.. Other then this, I can really recommend this kit, if you like Honda S2000..
Thanks again..
Old 08-04-2005, 05:54 PM
Dr.Gigglez's Avatar
Dr.Gigglez Dr.Gigglez is offline
Re: Completed - Honda S2000. Lots of Pics. 56K beware.
how did you paint the steering wheel so....perfectly...the honda emblem on the wheel is...perfect how'd u do it
-Paul A.k.A Dr.GiggLeZ
Old 08-04-2005, 06:16 PM
mickbench's Avatar
Re: Re: Completed - Honda S2000. Lots of Pics. 56K beware.
Cut the part from the sprue, cleaned up with sand paper (600 grit) and then primed with gray primer.
Sprayed a mist of semi gloss black twice, then a final wet coat of semi gloss black. The I applied a decal for the honda badge and set using micro set. Removed excess water and set solution and once dried applied a coat of micro sol to get the decal to look painted on. Once dried that was it.. Attached to the dash using Tamiya Thin Cement.
Old 08-05-2005, 08:49 AM
crisjr's Avatar
crisjr crisjr is offline
Send a message via MSN to crisjr
Very good job!!.. supa clean build!!!...iŽll look for other projects from you!!..
Cris
Cris Jr.
www.scalestreetracer.com
Old 08-05-2005, 09:40 AM
Lurchio's Avatar
Lurchio Lurchio is offline
Mick, I realise this post has been brought back but just curious - why do you primer before semi gloss black?
Do you find you get a better finish?
I never primer before using this colour/ silver etc as I find no diff in finish and if anything think it gives me better definition due to fewer paint layers.
Not saying I'm right just wondered on your opinion
Old 08-05-2005, 10:40 AM
mickbench's Avatar
I always prime the parts, no matter how small with gray primer so I can see any problems, such as mold lines, pin holes etc.. I've got a keen eye, but with gray primer I see it all so much better. Plus the paints seem to stick better to primer, and I get a less plastic look with some paints etc..!! I've done it for ages.. Primer is cheap, it's only a few quid a can..
Old 08-05-2005, 08:49 PM
CADguy's Avatar
CADguy CADguy is offline
It's very clean inside, outside and underneath.
Beautiful job.
Matt
Old 08-06-2005, 05:53 PM
indybhogal indybhogal is offline
WOW!! Looks great, wish my s2000 was as amazing as yours. LOL.
Old 08-06-2005, 07:12 PM
kunta's Avatar
kunta kunta is offline
Looks so clean, great work!
Old 11-03-2005, 06:16 PM
dustrman03
Guest
Posts: n/a
looks really good man
Old 11-04-2005, 02:42 PM
gpz900ra7's Avatar
gpz900ra7 gpz900ra7 is offline
There is no such things as mistakes in modelling, they are all happy little accidents . Keep up the standard, I'm well impressed with your quality work, RESPECT
Old 07-13-2006, 09:51 AM
silviadriverS15 silviadriverS15 is offline
i am strarting on s2000 too but i want to built a roll cage and exhaust
