Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 07-22-2005, 07:14 PM   #31
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: Re: Idle Out of Control (IOC)!
Originally Posted by tblake
its the last year they made them, they phased them out to start the impala in 2001. Why does that seem odd?
In 2000 when I bought the Impala, I actually wanted another Lumina, but they didn't have any, and said they wouldn't be getting anymore. They did say I could order one, but that Impala was sitting there screaming "Buy Me, Buy Me!"
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 07-23-2005, 01:02 AM   #32
tblake
In God We Trust
tblake's Avatar
wanna trade? I love impala's, I wish I had the kind of cash for one. The chevy garage in town has the nicest black Impala SS, I just drool over every time I drive by. But anyways, buck to the post, I would check the iac motor again, and make sure the plug and wires are in good shape, maybe exchange it (this doest work, can I exchange for another one) And see if that helps, maybe when you plug it in, spray the plug with wd40 or something, and make sure its seated right. Also I still think that there could be a vacuum leak somewhere, maybe get a vacuum guage hooked up and check for that. Your probably thinking "I;ve already tried all that", but thats all I have. Sorry strange one here. Good luck. Is it a constant very high idle, or does it increase very slowly, or is it like an idle like where someone has mashed the pedal to the floor. I had a high idle for a while in my 90 lumina, it wasn a pedal mashed high idle, but it was up there. It seemed to go away, so I thought nothing of it, sorry i cant be of better help. Good luck.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
tblake is offline   Reply With Quote
Old 07-23-2005, 01:04 AM   #33
tblake
In God We Trust
tblake's Avatar
what about a throttle position sensor?
Old 07-23-2005, 07:53 AM   #34
starla3366
Send a message via Yahoo to starla3366
Thanks tblake,
I still think there maybe a vaccum leak also. I didn't know of any tool that measures for vaccum leak. Do you have any idea of what it is called exactly and where I may be able to find/buy one?
Yes it is a constant idle, until I drive it for a while then it calms down. And it's a idle that's like a pedal about half way to the floor. but the throttle arm stays in the idle position. It does it right when I start it up, especially the first time i start it for the day.
Anyway, I am conviced there has to be a vaccum leak somewhere, unless someone else has any ideas
Thanks for the help,
tony
2000 Blazer LT
4.3 vortec
75k miles
K & N FIPK
starla3366 is offline   Reply With Quote
Old 07-23-2005, 09:27 AM   #35
cnilkyrclit
i actually had the same symptoms in my lumina (93 eurosport 3.1 v6) i changed the iac, for about two weeks it was fine. then when i would start it up the rpm's would run about 2 1/2-3000 rpm's. i was told that the computer was confused, and i needed to reset it. unplugged the battery for about 5 min., started driving at about 40mph for roughly 10 min., then got in the freeway punched it to about 80mph. afterwards every seemed to smooth out. i never actually tried the relearn process, just usaully drive for a good twenty minutes at various speeds. good luck.
cnilkyrclit is offline   Reply With Quote
Old 07-23-2005, 01:31 PM   #36
tblake
In God We Trust
tblake's Avatar
yeah, I think its just called a vacuum leak testor. Thats what i call it anyways. They may be kinda expensive, and there is a certain procedure for checking vacuum with one of these, I'm not exactly sure, someone knows on these boards, or else just have a mechanic friend do it. good luck
Old 08-01-2005, 05:35 PM   #37
starla3366
For everyone that was involved with me troubleshooting this ridiculous gripe, I want to say thank you.
I told everyone I would not give up, and that is just what I did. I never gave up, and I fixed the problem.
This is what I did to TRY to fix this gripe:
Replaced:
IAC
Spark plugs
Spark plug wires
All three Coils
TPS
All Vaccum Lines
All this totalling Over $100
This is what I did to FIX this gripe:
Replaced:
MAP Sensor
Totalling $2 from junk yard
ONCE AGAIN, THANKS EVERYONE!!!!!!!
Now the God Damn Power steering Pressure line sprung a leak.
Caused me three stitches trying to get the line out. Check out my newest post.
2000 Blazer LT
4.3 vortec
75k miles
K & N FIPK
Old 08-02-2005, 08:27 AM   #38
meuhus
ecm tester
what part stores have an ecm tester
auto zone doesn't
i do not think napa does either
i'd like to know
meuhus is offline   Reply With Quote
Old 11-13-2005, 06:09 PM   #39
MarkB
So The MAP eh? I guess that was just a guess? I'm going to give that one a try. Is you idle still good?
Cheers!
MarkB is offline   Reply With Quote
