Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 10-07-2005, 07:44 PM
Jaguar D-Type Jaguar D-Type is offline
Banned
Links to pictures
http://img36.imageshack.us/img36/9369/c6z0613hu.jpg
http://img36.imageshack.us/img36/4311/c6z0638fa.jpg
Lou Gigliotti's own C6 Z06. He has 20 wins in the Speed World Challenge.
Old 10-10-2005, 12:48 AM
Banned
"In place of the steel frame on the conventional C6, GM is substituting an almost identical aluminum spaceframe, thereby reducing mass by over 30%. The frame is produced for GM by the Structural Solutions Group, Dana Corp. Although it might seem like a simple substitution, according to William Kroppe, director, product engineering, at Dana's Structural Solutions, transforming a spot-welded steel frame into an aluminum structure held together by MIG and laser welds and self-piercing rivets while precisely maintaining the same dimensions as the original led Dana to a couple of industry firsts. Kroppe points out that while many automakers have produced aluminum-bodied vehicles that use panels on the order of 1-mm thick, few have worked with the 3-mm+ thicknesses needed for an aluminum frame.
The Corvette Z06 aluminum spaceframe is a smorgasbord of aluminum castings, extrusions and stamped panels. Dana uses 14.2 meters of laser welds and 238 self-piercing rivets to assemble the frame. Hydroformed side rails come from GM's Metal Center in Pontiac, MI. The total part count for each frame (excluding fasteners) is 90, which is lower than that of its steel counterpart.
Dana has carved out a small cellular assembly area for the Z06 in its manufacturing facility in Hopkinsville, KY, that is otherwise dedicated to producing serious volumes of stamped and spot-welded steel frames. (Annual volume for the Z06 is projected at 7,000 units.) "Compared to the other frames we make in that plant, this is Swiss watch work," says Kroppe. To prove the point, he describes how the aluminum castings that provide the attachment points for the suspension components are CNC machined with a precision that exceeds steel frame fabrication techniques. To achieve the highest degree of dimensional accuracy, Dana found it best to assemble the body first and then machine it using a Tricept robot from ABB."
- autofieldguide.com
http://www.dana.com/
http://www.abb.com/
12. Magnesium steering-column bracket
17. Aluminum brake and clutch pedals
18. Hydroformed lower instrument-panel tie bar
20. 370mm 3-spoke steering wheel
15. Aluminum unequal-length control-arm suspension
27. Short-throw 6-speed manual transmission, rear-mounted transmission and axle collers, larger rung gear rear axle
2. High-strength bumper beam
13. 3-inch stainless-steel exhaust with polished 4-inch tips and Pierburg valves
4. High-strength bumper beam
14. 7.0 liter LS7 V-8 engine, 505 hp, 427 cubic inches, titanium valves and connecting rods
7. Aluminum wheels, 9.5 x 18 front
8. 275/35ZR-18 Goodyear Eagle F1 Supercar EMT front tires
9. 14-inch cross-drilled rotors with 6-piston calipers with individual pads
1. 13.4-inch cross-drilled rotors with 4-piston calipers with individual pads
6. Aluminum wheels, 12.0 x 19 rear
16. 325/30ZR-19 Goodyear Eagle F1 Supercar EMT rear tires
The following information and pictures are from motortrend.com:
1. Splitter and 30-percent-larger grille opening make Z06 a front breather; base car is a bottom breather.
2. Intake air enters through new nostril.
3. Black fender lips at the leading edge of the front wheel openings direct air around the wide tires. Generous radius at trailing edge of fender liner smooths airflow, deflects stone damage.
4. Carbon-fiber front fenders widened slightly and incorporate larger functional air exhaust scoop. Must be clamped to a painting fixture, or the sprayers blow them away.
5. Hatchback body style weighs 22 pounds more than the previous Z06's notchback, but greatly improves aerodynamics. Lightweight Plexiglas considered for the hatch flunked GM's ultraviolet stability and scratch-resistance tests.
6. Rear SMC quarter panels widened by 1.5 inches each to clear wheels that are two inches wider than the base car's.
7. Tall Gurney-lip ducktail spoiler reduces lift.
1. Hydroformed structural side rails are geometrically identical to their steel counterparts. Remaining aluminum castings, stampings, and sheets are attached via metal-inert gas welding, laser welding, and riveting. Dana Corp. builds the structure.
2. Six-piston calipers chomp on 14.0 by 1.3-inch rotors in front, four-piston calipers and 13.4 by 1.0-inch rotors suffice in back. Ceramic brakes were planned for the Z06, but won't be implemented until costs fall sufficiently to market them as a $4000 option.
3. Magnesium roof structure from coupe's removable panel gets bolted in permanently. Maintaining the desired chassis rigidity with a removable roof would've required 44 pounds of added structure.
4. Balsa-wood core floor panels are sandwiched between layers of carbon fiber instead of fiberglass, adding strength and reducing weight.
5. Springs and bars stiffened all around. Sachs monotube shocks fitted (the magnetic shock fluid can't withstand severe track duty).
6. Exhaust flows through short tubular header pipes into a large four-into-one collector chamber and then to a high-flow catalyst through three-inch pipes to two giant mufflers. Each has a mechanical flap that opens above 3500 rpm near wide-open throttle for straight-through flow. Result: 38-percent-less back pressure than in LS2.
Items that add weight: pounds
-Upgraded brakes 27.6
-Dry-sump, extra oil, oil cooler 23.1
Three-inch exhaust and valved mufflers 11.7
Larger differential with cooling circuit 11.0
Rear-mounted battery (cables and bracket) 8.8
Larger wheels and run-flat tires 6.2
Items that subtract weight:
Aluminum chassis structure 136.7
Reduced interior content*
*(electric seat bolsters, six-way passenger-seat adjustment, acoustic damping material) 33.0
Magnesium engine cradle 11.9
Removable roof hardware 6.6
Carbon-balsa floor panels 5.3
Carbon-fiber front fender liners 2.2
Old 10-18-2005, 03:19 PM
Banned
check the link for a video
C6 Z06
Old 10-27-2005, 08:37 AM
StreetRacer4Life's Avatar
StreetRacer4Life StreetRacer4Life is offline
the new Z06 is crazy! 0-60 in 3.7sec in first gear thats nuts! any clue on what its 0-100 time is or its top speed?
Old 10-28-2005, 01:20 AM
Banned
The new aluminum Z06 has a top speed of 198 mph (drag limited).
The following is from Car & Driver October 2005 except where otherwise noted:
Zero to 30 mph: 1.6 seconds
40 mph: 2.2
50 mph: 2.8
60 mph: 3.4 (Car & Driver December 2005)
70 mph: 4.5
80 mph: 5.5
90 mph: 6.7
100 mph: 7.8 (Car & Driver December 2005)
110 mph: 9.3
120 mph: 11.0
130 mph: 12.8
140 mph: 15.0
150 mph: 17.5
The following is from Motor Trend October 2005:
Standing 1/4-mile: 11.5 sec at 127.1 mph
Lateral acceleration: 1.05 g average
Braking, 60-0 mph: 104 feet
Old 11-03-2005, 07:27 PM
Banned
Front 6-piston caliper
Old 11-13-2005, 06:21 PM
Banned
Check the link for a cool picture
http://www.treynor.com/BigRedZ.jpg
Old 11-14-2005, 10:28 AM
Indycarlover Indycarlover is offline
Re: 505 hp Corvette Z06 pricing and what not
Yes, very impressive indeed!
Owner: Autofreefinders.com
A for sale by owner online auto mall
Over 10 years in business
Indianapolis Indiana
Drive: 86 Porsche 944 & 90 300 ZX
Old 11-22-2005, 06:46 PM
Banned
The following is from the January 2006 issue of Sports Car International on page 35:
"The net result is a fully trimmed engine that weighs 458 pounds, only 10 more than the 6.0-liter LS2."
Also, BMW's M5 Product Information Guide says that the 5.0 liter 500 hp (SAE net) V-10 weighs 240 kg/529 lbs.
Old 12-02-2005, 02:39 PM
kachok25 kachok25 is offline
I have finnaly foud it an american car that I would take over a Supra anyday. GM finnaly built a viper killer hell yea. I cannot wait to rob a bank and go get one.
Old 12-07-2005, 05:04 AM
Banned
New Corvette Z06 GT3.Rs will race in the FIA GT's new GT3 class as a support event to the FIA GT Championship.
http://fiagt.com/newsitem.php?key=816
Another link
Corvette Motorsport
Ernst Woehr of Callaway and Toine Hezemans of Carsport Holland have "expressed interest" in the new GT3 class.
Check the link for Callaway's update
Callaway
Callaway Engineering and Cyclone Power Ltd. have debuted a 550 hp V-16 engine. It would be the first automotive production V-16 engine if it were built since Cadillac's V16 of 1930-1940.
check the links
Cadillac V16
V-16
V-16 pictures
Old 12-12-2005, 03:38 AM
Banned
Old 12-14-2005, 07:41 PM
Banned
The new Chevrolet Corvette Z06 has been named an "All-Star" by Automobile Magazine.
The Automobile Journalists Association of Canada (AJAC) introduced a brand new award for a "truly exceptional vehicle that sets new standards". The inaugural AJAC 'Most Coveted Vehicle Award' went to the 2006 Chevrolet Corvette Z06.
The Chevrolet Corvette C6 was named Car & Driver's "10Best Cars: Best Performance Car" for 2002, 2003, 2004, 2005, 2006, and I might have missed some years.
"For two years in a row, our readers have declared the Corvette as the winner of the Road & Track Readers' Choice Award: Best Car. This year, the high-performance 505-bhp Z06 gets the crown."
- roadandtrack.com
Old 12-24-2005, 04:25 PM
Banned
The GM badge seen just in front of the rear wheels can be removed.
The speedometer of this Z06 shows km/h and not mph.
Old 01-01-2006, 08:44 PM
Banned
The Z06s shown in the links are at Belgium's Spa-Francorchamps circuit which hosts the FIA GT Championship's 24 hours of Spa. It is a very challenging race track.
Red Z06 at Spa
Yellow Z06 at Spa
