Old 05-27-2005, 07:32 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Re: Re: Re: Re: Whats under your hood?!?!
Originally Posted by krustindumm
check the torque of your passenger side axle nut. improper tq can cause bearing noise. Correcting it may fix it if damage was not already done.
Pardon my ignorance, but which nut exactly do you mean? the spindle nut? The wheel spins straight and there is no movement except for some slight (like 1mm) of play in the axle itself. Thanks!
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 05-27-2005, 05:53 PM
krustindumm's Avatar
krustindumm krustindumm is offline
the nut on the end of the axle is used to preload the bearing. In the rear it is a spindle nut, since there is no axle, in the front it is the axle nut.
91 Civic Dx Hatch
Midwest Honda's MySpace group
Old 05-27-2005, 07:26 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
d15b7 so i guess its newer than the stock b2 but same hp. i got a intake, thats it.
hopefully in 2 month ill get my lsvtec in with soem sort of stage 2 cams, b16 pistons, exedy flywheel, dc headers, dsm 450s, uberdata tuned. actually looking at it now, looks like 3 months, lol.
Team Lonely Drivers
Old 05-27-2005, 07:37 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
lol, and then 3 months will quickly turn to 4, then 5 and so on, trust me my year and half build of my b18c1 was only supposed to take 7 months including install...
Old 05-27-2005, 07:49 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
yeah my 3 month assembly of my EF is still ongoing at 2.5 years. damn conversion ideas and more parts keep it off the road
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-27-2005, 07:52 PM
after calculating costs, i came up with 3700 roughly, i make about 1300 a month, so i figure in 3 months with 3900, that should take care of all the unexpected costs.
hasports mounts - 500
clutch&flywheel - 500
syncros ls trans - 200
b16 obd1 dist - 200
obd1-obd0 conversion - 100
p28 ecu socketed - 150
laptop - 500
uberdata equipment - 600
cams and retainer - 800??
GE lsvtec kit - 200
idk might have to forgo the cams for now. i have to go back to school in august so im just going witht he bare essentials first, i might not even have the money in time to tune it with uberdata, might just have to run off a stock pr3 or p30. but yeah i know what your talking about, about it taking way longer than expected
Team Lonely Drivers
Old 05-27-2005, 07:53 PM
Kind of a Big Deal
any a lot more money... my motor was only supposed to cost about 10g's and im up near 13 now and still going..
Old 05-27-2005, 08:46 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
all i have is a JDM DOHC ZC
Vibrant Intake with APC Filter
Minor P&P (and portmatched)
bored throttle body
Airmass 2pc Header
2.5 inch exhaust from the header back with a cherrybomb as a resonator and a dual square DTM muffler
all mated 2 a 90 Si trans with a Dynapak clutch
and i as well have done alllllll my work myself
Current status... Running strong with the TPS unplugged haha
Old 05-30-2005, 02:18 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
jdm D15b vtec /p28, obd1 set up
short ram intake
dc 4-1 header
2.25 exhaust no cat dyno max super turbo muffler ...made to look stock.
zex wet kit , 50 shot
nothing fancy and i do need to update my cardomain, lowered on arospeed coilovers (not bad)
i still want to do the teg rear disk conversion and i need a camber kit...still
all rolling on 15x6.5 Talon's (ICW Racing) with goodyear eagle GT's
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 05-30-2005, 05:35 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
My setup:
JDM 97 B20B
Y1 B16 tranny
Stg. 1 EXEDY clutch
33mm intake valves
combustion chambers opened to 84mm (combustion lowered to 8.3:1)
ported head
AEM adjustable cam gears
B&M fuel pressure regulator
Apex'i SAFC
DC Sports 4-1 w/ 2.5 inch collector (JDM ITR)
Catco high flow cat 2.5 inch
2.5 inch full karns motorsports exhaust
NGK plugs and wires
JDMshit.com Carbon fiber hood
Falken Azenis tires w/ del sol Si wheels
SPC camber kit
Parts sittin in garage:
Garrett T3 turbo .52/.48
RevHard intercooler
NSR technologies Turbo Manifold
TurboXS Type-H RFL Blow off valve
Denso 360cc Injectors
NGK BKR7E spark plugs
Downpipe Flange
Vacuum Hosing and brass T's
Coolant hosing
Parts in the mail:
Fast-turbo.com turbo oil line kit
Tial 38mm wastegate
Intercoolor Couplings and hoses
ATPTurbo.com restrictor valve
Parts i still need:
Intercooler piping welded
downpipe made
turbo coolant fittings, etc.
92+ civic radiator
Give me 1 more month and i'll be boostin'!
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 05-30-2005, 09:44 PM
Mrock Mrock is offline
Send a message via AIM to Mrock
Mine's in my sig..DOHC ZC with bolt-ons.
ZC powered '91 CRX...JE 10:1 pistons, Crower rods, Bullfrog cams, Throttle body bored by Gude, Port and polished head, AEM adjustable cam gears, 340cc injectors, MSD SCI ignition, Cold air intake, clutchmaster stage 2 clutch, aluminum flywheel/heavy duty pressure plate, zex nitrous kit.
Waiting to arrive (and install, to get this baby running!)
Walbro fuel pump, PWR radiator, PM7 ECU
Look out, I can run 17's allllll day.
Old 05-30-2005, 11:09 PM
WhiteRanger WhiteRanger is offline
91 TGP DX Hatch
SOHC VTEC Turbo
Old 05-31-2005, 09:05 AM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
there's nothing under my hood
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 06-01-2005, 12:33 AM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
And now whats under my hood:
JDM D15B VTEC
OBD1 P28 ECU (well, not under the hood but u get the idea )
NGK Plug Wires
'eBay special' Cold Air Intake (not in the pic)
Megan Headers (not in the pic)
Excedy Stage 1 Clutch
(just finished my swap today)
Old 06-01-2005, 08:15 PM
i think you're going to be happy with the d15b vtec... mated with a Si tranny low 15s are possible for cheap!
