Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Camaro Discussions
Old 04-14-2005, 02:33 AM   #31
supercarvideos
Re: Re: Experienced TPI guys front and center...
eBay..... (I am an eBay junkie...LOL!!!!) You can find a whole disc rear in your area, and everything to swap it.... just have to keep searching, one week maybe nothing, then the next, JACKPOT!
supercarvideos is offline   Reply With Quote
Old 04-24-2005, 05:58 PM   #32
grim0404
hey i have a 92 k1500 pick just bought a 89 tpi base plate runners and plenum also a 92 ecm my truck has 180 000 and still running strong but want more power what do you recomend??
grim0404 is offline   Reply With Quote
Old 04-24-2005, 07:55 PM   #33
89IROC&RS
89IROC&RS's Avatar
Re: Re: Re: Experienced TPI guys front and center...
Originally Posted by Morley
$400 for the SD vortec TPI base..junkyard heads are usually just that...junk, may need new valves, seats, guides due to rust.
The SD base also needs qite a bit of porting to come anywhere near a 20-25 hp gain and porting a TPI intake is no small chore.
dunno about the junkyard heads, mine were just fine. I gave them a day or two in the parts cleaner bin at work, and some time with a whiz wheel and then rubbed them down with WD-40 to keep them from rusting. Once i cleaned em up they looked brand new, even the valves. I chose to throw away the old valve seals and put new ones on. My heads came from a wrecked 99 tahoe and all the parts were in great shape. Of course you have to do all the junkyard checks regarding the condition of the oil, checking for coolant contamination, turning the engine over to make sure it rotates smoothly and all that. But for the little bit of work invovlved you save a helluva lot of money.
As far as the power from the SD baseplate, ive seen dyno tests that back up the 20+hp claim on a bolted on unit, no porting. Remember it was designed for the vortec port sizes and has much larger ports because of it that flow more air.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
89IROC&RS is offline   Reply With Quote
Old 04-25-2005, 02:22 PM   #34
supercarvideos
Re: Re: Re: Re: Experienced TPI guys front and center...
Remember the special plug socket I was telling you about...? I just noticed that SLP also offers the same type socket... use it with a 3/4" gearwrench, and you will never dread the plug swap again....
another thing, I just noticed that you are also located in Northern Va. I am in Winchester... I've been thinking of organizing a "late model car club" for '85 and later Camaros, Mustangs, GNs, etc.... any interest in putting something together with me?
www.supercarvideos.com/IROC
