Old 03-23-2005, 11:11 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 95 p0306, changed plug&wire, still misfire
If it was in a wreck, chances are the heads will be fine.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-23-2005, 11:16 PM
Turbocpe Turbocpe is offline
Good word, it is a chance. You aren't willing to chance a CPI unit which is much simpler bolt on device, but you're willing to chance heads?
They have their places, but in this case, this is not something I would do. But that is my opinion.
Old 03-23-2005, 11:21 PM
BlazerLT's Avatar
AF -Advisor
comparing a factory flawed CPI injector swap to a good head from a body wrecked low mileage 1995 engine is ridiculous and you are now nit-picking my answering in other threads to back your point?
Comon now.......
Old 03-23-2005, 11:27 PM
I'm not nitpicking. You acknowledge it is a chance, yet you are against it for something much more simpler, less time involved, and reveling.
Have you done any deep work like that?
Sure, you should/could have the heads checked.
Low mileage does not always or automatically mean good. That would be an assumption.
Old 03-23-2005, 11:30 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: 95 p0306, changed plug&wire, still misfire
It is an option, I am not arguing that the valve seal swap is a bad idea, I am giving the guy other options to look into.
So please understand that.
Old 03-25-2005, 05:00 AM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
i just noticed this today. when accelerating the RPMs twitch. like 300 at a time. they go up and down like 150 each way. while misfiring that is.
Old 03-26-2005, 08:28 AM
it is almost like the gas is pulsating. like it sends gas in then cuts off for a split second, then gives gas again. it isnt getting any better with a new tank of gas from a different gas station. whats next for me to do?
Old 03-26-2005, 09:14 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Have you pulled your plenum to check for washing? Again, one of your poppets may be stuck open. Your fuel pulsator may also be going out. Have you run a pressure test at the shrader valve?
Old 03-26-2005, 01:10 PM
where is the shrader valve? 95 W 4X4 4.3
Old 03-27-2005, 05:08 AM
rlith's Avatar
Back of the plenum on the inbound fuel line, looks like a fat tire valve (may have a black plastic cap on it)
Old 03-28-2005, 07:57 PM
i also noticed today that my car is running a little colder than normal. not too much but 2 notches. you make anything of that? im bringing my blazer into the shop tomorrow. to a known mechanic of the family for about 20 years. but id like to try something else before i put it in there. so anything?
Old 07-31-2005, 08:39 AM
Hobiehunter Hobiehunter is offline
40000 mile 4.3 vortek, blue smoke first start up in the morning, valve seals leaking.
