Old 03-26-2005, 10:23 AM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: Re: Re: Re: 95s-10 hard starting when warm
Originally Posted by rlith
No, you have CSFI, similar to CPI but sequentially fired (CPI was discontinued in 95)...If you're running rich one of your injector hoses may be bad. (also causes misfires)
I just checked the codes and I'm getting a P1351(Ignition control circuit voltage high and ignition control circuit open).Is that weird there 2 descriptions under one code? I am also getting a PO420 code(Catalyst system efficiency below threshold,bank 1).Would this fall under your injector hose threoy?What's involved in changing them?
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 03-27-2005, 02:43 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Re: Re: Re: 95s-10 hard starting when warm
Ok, the P0420 code seems to point out that you cat is screwed or the O2 sensor behind the cat is bad. More than likely the cat is plugged.
More info here:
http://www.obd-codes.com/trouble_cod...old-bank-1.php
The other two codes will point to a bad ignition switch.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-27-2005, 05:48 PM
Re: Re: Re: Re: Re: Re: 95s-10 hard starting when warm
More info here:
I think somebody hollowed my cat out because it has a hollow sound to it when it's running(before I bought it).I know this because I poked out the wife's cavalier cat and it has the same hollow sound and also threw the PO420 code.The O2 sensor is new.Now this ignition switch.Would that cause the hard starting issue?Why would it fire right up when it's cold,but not whens it's warmed up?Is it the injection issue that this other guy is talking about?This truck is a constant pain in my ass!
Click here
My $12.00 Sunfire
Old 03-27-2005, 09:22 PM
BlazerLT's Avatar
AF -Advisor
Could be that.
Also, check your fuel pressure.
