Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-23-2005, 12:55 PM
unemployedsnail unemployedsnail is offline
3.2L 4x4
139,500
ABS & brake indicator lights constantly coming on and going off, serpentine belt squeals, brakes squeak, spare tire latch won't open
Old 03-24-2005, 09:19 PM
IHakki IHakki is offline
I am on my second Rodeo - First one was:
Year:1998 2WD
Engine:3.2 V6
Mileage:85K
Any major problems: Only an alternator
Second (current) one:
Year:2001 LS 4WD
Engine:3.2 V6
Mileage:135K
Any major problems: None - The only "broken" part was an A/C clutch and ended up replacing everything (compressor, evaporator, expansion valve, etc)
As "routine" maintenance, changed:
Shocks, plugs (at around 70K), timing belt, water pump, dropped the transmission pan and replaced filter, fluid (~80K)
Most of my 135K are highway miles - Both vehicles have been very good to me!
Hakki
Old 03-25-2005, 07:10 PM
budnik1 budnik1 is offline
Re: How many miles do you have your Isuzu?
1994 Rodeo v6 2wd
188,000 miles
I bought it with 179,000 far as I know no maintinence but clutch.Timmimng tensioner just went last week .I replaced timing belt,tensioner,tensioner pulley,idler pulley,water pump.all today,It still needs valve cover gaskets ,spark plugs,wires,leaking oil around fliterand oil cooler not sure what is leaking.
Old 03-26-2005, 09:27 AM
hawkeye2700 hawkeye2700 is offline
Year:1993 4WD
Engine:3.2 V6
Mileage:241,000
Any major problems:None
Only thing I had to replace was the fuel filter
Old 03-31-2005, 01:36 PM
daisyland67 daisyland67 is offline
Send a message via AIM to daisyland67 Send a message via Yahoo to daisyland67
year:1994 engine:3.2 v6 mileage: 170900m MAJOR issues: outside of the regular fluids, changed oil every 3000 miles, battery and 2 sets of tires, water pump, timing belt, fuel filter due to receiving bad, contaminated gas loaded with rust and sand!!!!, 2 oxygen sensors, alternator, and several seals. the vehicle is GREAT!!! i love my truck!!!
Old 04-03-2005, 12:06 AM
cjerome74 cjerome74 is offline
Year : 2002
Model: Rodeo LS 2wd V-6
Mileage: 22800
Recent Issues: Check Engine Light on (Code P0155)
Status: Shopping for a reliable resource to make scheduled and required repairs and adjustments.
Driver status: my wife drives it on the weekdays, and I use it on the weekend.
Old 04-05-2005, 01:42 PM
Jimbeaux's Avatar
Jimbeaux Jimbeaux is offline
2000 Rodeo
3.2 V6
110,000
Major Problems: WELLLLLLLLLLLLLL...!!!!!!!
I had to change the engine besause of a spun rear main. I usually check the oil every 2 weeks. My EGR valve plugged up and from what I have researched it will cause the engine to burn oil. Sooooo anyway I had to replace the engine. Now that it is done I have a transmission leak that was caused from the engine swap.(see my post under transmission problems to read the whole story) I have an appointment tomorrow to fix that.(with a a real transmission repair shop)
Anyway, I love my 'Rodeo. I travel every year to NewMexico from Houston puling my motorcycle and it just fly's over the mountains. I hope they come out soon with a new model of the Rodeo????
Jimmy in Texas
2008 Suzuki XL7 (Mommas)
91 BMW K75 My Toy
04 Ford Escape (Mine)
98 Ford Mustang My Daughter$
Old 04-07-2005, 12:36 PM
Bonzmobile's Avatar
Bonzmobile Bonzmobile is offline
3.2L
208,500 miles
Had to do some routine fixes for lack of maintenance. Wheel bearings, shocks, belts and hoses, tune up. Replaced the water pump, a rear window regulator(junk yard $20), front seat(junk yard $20 too). Wish I knew about the T.B. tensioner noise issue when I replaced the water pump!
Struggling with an electrical gremlin right now. See post.(Fixed it! 4/19)
Just bought the truck last summer from the original owner. Wanted a good old SUV to take the pooch to the park and keep the hair and mess out of my car. Love that it holds a couple of 4x8 sheets and hauls lots of tools too!
'93 Rodeo 3.2L 2WD 5sp. 235,000miles and that's Bonz smiling in the back! SOLD
'95 Passport 3.2L 176K
Old 04-11-2005, 01:08 AM
matemk matemk is offline
Send a message via AIM to matemk
1992
3.2 V6
151000
Major problems: oil leak from valve cover gaskets, transmission fluid leak, coolant leak, Leak in Master Cylinder, No 1st gear, and a bunch of other little stuff
Old 04-11-2005, 11:25 AM
Javan Javan is offline
Thumbs up running strong
Year: 1998
Engine: 3.2L V6
Mileage: 162,000
Any major problems: Noting Major, Replaced Transmission selector Switch @ about 150,000 miles for about $300. Replaced Idler Pully @ about 124,000 miles for about $16. Thats it outside of scheduled maint.
I bought this one with 120,000 miles on it a little over a year ago. Since then I have been putting anywhere from 700 to 1500 miles a week on it.
(wish it came in a diesel!)
Old 04-11-2005, 12:51 PM
BorysKndrt's Avatar
BorysKndrt BorysKndrt is offline
1997 Honda Passport
3.2L V6
126,589 Miles
Replaced all the belts and hoses, at 100,000, and the alternator at 120,000.
Old 04-12-2005, 08:57 AM
sfrodeo04 sfrodeo04 is offline
Thumbs up
Had a '96 Rodeo...traded in for an '04 last summer (after 80K easy miles, sorry for driving only 10K/year).
Replaced radiator (recall), all tires, timing belt, water pump, everything else was scheduled maintenance (LOF, tire rotations, etc).
'04 Rodeo - One issue with ABS light (brakes locked up while sliding down ice covered driveway backwards) - no repair, plus one rear end collision (I stopped 30' short of the pileup, Toyota Tacoma behind me didn't) about 2K to replace bumper, impact attenuation gear, repaint...
Too bad there's no '05....
SF
Old 04-16-2005, 04:07 PM
go4it487 go4it487 is offline
146000 miles
99 rodeo
3.2 lt
136,000
did replace the fuel sending unnit at 100,000 and
replaced tires at 110,000 , new abs module, 1st new battery, 1st surpetine belt , 1st starter, and routine maintanence every 3000 miles.
Old 04-21-2005, 07:05 PM
lifelongslacker lifelongslacker is offline
97 Rodeo
3.2L V6
97,800
Replaced Shocks a few weeks ago
Old 04-22-2005, 11:59 AM
BamaRodeo BamaRodeo is offline
Year: 1999
Engine: 2.2L
Mileage: 49,150
Any major problems: No MAJOR problems. Recall on Timing Belt & Tensioner at 25k. Replaced: top oil gasket, fuel sender unit, right door mirror, belts.
'99 2.2L Rodeo
'06 Mini Cooper
w/ guitar in back
