Old 03-13-2005, 03:44 AM
TvD's Avatar
TvD TvD is offline
Registered User
Re: WIP : Subaru Impreza Rally Japan 2004
Originally Posted by Sennake
The WRB was spraypainted with Tamiya TS-50 "mica blue".
Just wondering; did you spray from the can, or did you de-can it and used an airbrush???
And congrats on your 1st prize!!!
Tim
Old 03-13-2005, 04:47 AM
Sennake's Avatar
Sennake Sennake is offline
Re: Re: WIP : Subaru Impreza Rally Japan 2004
Tim
I just sprayed it "straith-from-the-can".
I know some guys decan it to use their airbrush, but to me that takes away all the time-advantage of a can. If I weren't so lazy, I would use my airbrush all the time, but I just hate cleaning it out every time after spraying. I think it's a loss of time, time I could use better by modeling other things. But that's just a personal opinion of course.
I use Tamiya spray-cans for 95% of the parts I paint. Not just for bodies, but for every single little part of any model as well. And it works well or me, so I don't see any reason to change that...
* WWW.SENNAKE.BE *
Old 03-13-2005, 06:39 PM
RallyRaider's Avatar
Zomby Woof
Great build, congrats on the win and iminent publishing!
Doesn't using cans for everything cost a lot? I find an airbrush much more efficient, less wasted paint in overspray.
Old 03-14-2005, 01:16 AM
Sennake's Avatar
Probably yes, but as "time is money", I save a lot of time so I can afford to lose some money
* WWW.SENNAKE.BE *
Old 05-31-2005, 01:24 PM
grega x grega x is offline
Did u use a primer or you just painted it without any priming.
I am about to start with mine Impreza, and i wonder.... i have gray surface primer from tamiya, and spraying Ts50 over that would turn the paint darker, I guess?
What dou you reccomend?
Old 05-31-2005, 07:54 PM
mozli's Avatar
mozli mozli is offline
quoted from the FAQ:
"Guiddy wrote a whole thread with step-by-step instructions.
Painting model car bodies! Full instructions! (Yes, you have to use primer!)"
Old 05-31-2005, 11:12 PM
A_C A_C is offline
Re: Re: Re: WIP : Subaru Impreza Rally Japan 2004
Glad to meet another "straith-from-the-can" modeler. Besides time & money, I'll treat it as a personal practice.
Congratulations on both your win & publish. It'll be perfect if the side mirrors and the rear spoiler were wrapped with carbon fibre. Anyway, nice work! The antenna looks terrific.
Old 06-01-2005, 02:57 AM
Sennake's Avatar
Re: Re: Re: Re: WIP : Subaru Impreza Rally Japan 2004
Uhm... they ARE...
* WWW.SENNAKE.BE *
Old 06-01-2005, 03:44 AM
A_C A_C is offline
WOW~ finally we can view the real product~~
Old 06-01-2005, 03:50 AM
Aras Aras is offline
Hi Tim,
Congratulations!
Your model is one of the nicest I've ever seen.
Please tell me, how did you put CF declas on rear wing?
The outcome is perfect....
Regards,
Aras
Old 06-01-2005, 04:44 AM
Sennake's Avatar
I'm not sure whether I should be answering this question, since I'm not Tim, but ok.
I made 30 templates with Tamiya masking tape and then I applied those 30 decal parts to the wing. Sounds easy, is pretty easy, but it's sure time-consuming : it took me a whole week all together.
After the decals are completely dry, I applied 3 coats of gloss varnish to give the CF-effect a more realistic look.
* WWW.SENNAKE.BE *
Old 06-01-2005, 02:52 PM
Hi Guy,
The model looks awesome even if you're not Tim ;o)
thanks for your CF tip.
Aras
Old 06-01-2005, 03:04 PM
blubaja's Avatar
blubaja blubaja is offline
Yyyyyyyyyyyeaaaaa!!!!! :-D That's so dam awsome man! How did you do the antennae? Beatiful!! Realistic!! Keep up the great work!
Frank X.
Old 06-01-2005, 03:26 PM
Sennake's Avatar
Frank X.
Well, I cut off the original antennas from their supports, then I drilled out a tiny hole in the centre of those supports, and then I glued pieces of guitar string (thinnest string - high E) in the holes.
* WWW.SENNAKE.BE *
Old 06-01-2005, 05:23 PM
DJPaul DJPaul is offline
are you sure it is not real car.
Absolutely stunning. WOW!!!
A+++
